IDI PROBLEMS
Old Dec 9, 2012 | 05:25 PM
LoganIDI's Avatar
LoganIDI
IDI PROBLEMS
I have a 1992 7.3 IDI 5 speed manual. When I am driving down the road normally not accelerating or decelerating it dies.. Just shuts off.. It also idles up and down while driving.. I have no idea what this could be.. Any help would be appreciated! I'm new to all this
Old Dec 9, 2012 | 06:33 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Sounds like a sticking governor in the Injector pump.
Get some Howes Diesel conditioner.
Take the fuel filter off (even better replace it with a new one if is hasn't been done in a while), fill new one up with nothing but Diesel conditioner, fire up engine for 20 seconds, and shut down. Let it sit a minimum of an hour, even better overnight.
Next day fire 'er up, let it warm up abit, and go drive it like you stole it. Should fix the problem.
And visit this forum next time for quicker answers regarding the IDI Diesels.
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
Old Dec 9, 2012 | 08:32 PM
LoganIDI's Avatar
LoganIDI
That's the thing though man I just replaces the fuel filter not even 3 months ago.. But what exactly does that **** do?
Old Dec 9, 2012 | 08:33 PM
IDIDieselJohn
It cleans and lubes the fuel system.
Old Dec 9, 2012 | 08:36 PM
LoganIDI's Avatar
LoganIDI
So it's probably something wrong with the fuel system? Doesn't sound as bad as what I expected
Old Dec 9, 2012 | 08:37 PM
IDIDieselJohn
Could be just a sticky governor spring in the IP.
Old Dec 9, 2012 | 08:41 PM
LoganIDI's Avatar
LoganIDI
Alright thanks
Old Dec 11, 2012 | 10:33 AM
irhunter's Avatar
irhunter
How did this work out?
This: "Just shuts off." sounds like a fuel shutoff solenoid to me.
Old Dec 12, 2012 | 03:15 PM
LoganIDI's Avatar
LoganIDI
Yeah but it starts right back up again.. If the solenoid was messed up it wouldn't start I don't think
Old Dec 12, 2012 | 03:41 PM
irhunter's Avatar
irhunter
Well, there is a "solenoid problem" and there is a "power-to-solenoid problem." I think electrical supply issues (including ground issues) are often intermittent.
Old Dec 12, 2012 | 04:18 PM
farmerobrown's Avatar
farmerobrown
Get you some marsh mellows-it may shoot out some flame when that conditioner cleans the crud out, wether you have a electrical problem or not.
Old Dec 12, 2012 | 04:22 PM
farmerobrown
Wonder what year that these problems were worked out?
Old Dec 13, 2012 | 06:54 AM
LoganIDI's Avatar
LoganIDI
I have no clue. I mean there is just so many things that it could be. I'm really starting to think it's the fuel pump (lift pump)
Old Dec 13, 2012 | 12:36 PM
irhunter's Avatar
irhunter
Are you running the original mechanical lift pump? Or, and after-market electric pump? I can't see your symptoms coming from a mechanical pump. I have found they work poorly all the time, or they don't work at all, or they are OK. Not much chance of intermittent.
Have you checked the electrical connections leading to the fuel solenoid? Clean tight connections?
I have more experience with Cummins; with that motor, we take the guts of the FSS out and then turn the motor off by way of a lever on the injection pump. If the symptoms get better once the FFS guts are out...then, the FFS was the problem. I don't know if the IDI IP has a manual shut-off lever.
One Entwademalia
Apr 14, 2019 03:22 PM
adamkat22
Aug 7, 2017 11:18 PM
chakes
Jul 11, 2017 05:44 AM
Dodge-My-Cummins
Sep 21, 2010 08:30 PM
jhkfarms
General Diesel Discussion
Oct 29, 2009 05:51 PM
