Changing fuel filter (Priming it) question
Old Sep 19, 2010 | 06:06 PM
Dodge-My-Cummins's Avatar
Dodge-My-Cummins
Hey guys I'm working on a 92 F-250 7.3 IDI that has been sitting for a few years, It runs pretty good at idle but up around 2000 rpm it breaks up a little and white smokes at startup pretty bad too.
the fuel filter looks old so I'm gonna change it but I'm told filling it with diesel injector cleaner first is a good idea because it saves me from having to get a can with diesel fuel in it and it will also clean out the injection system.
I just don't know what to use.....Seafoam? Diesel Kleen?
What do you guys recommend? Theres this stuff at Napa for Diesels that they highly recommend, It's in a purple and silver can and has a german name but i can't remember it?
Thanks
Brandon
Old Sep 19, 2010 | 06:49 PM
WarOzz's Avatar
WarOzz
Well your headed down the right road. I have used both ATF and Diesel Kleen... I prefer the DK.
First warm up the truck real good.
Pull old filter and toss it.
Fill New filter with diesel kleen.
Start truck let run 10 to 15 seconds and shut it down.
Let truck sit as long as possible up to 24 hours.
Warm it up and drive it like ya stole it for 10 to 15 miles.
This will clean out your injectors and could make it feel like a new truck again.
Old Sep 19, 2010 | 06:55 PM
oreocreaming's Avatar
oreocreaming
DK burns better, ive had issues firing up with atf a few times.
Old Sep 19, 2010 | 07:01 PM
kenpobuck's Avatar
kenpobuck
I personally swear by seafoam. It does wonders on fuel systems. I use it about twice a year on everything I own and have had great luck with it.
Old Sep 19, 2010 | 07:11 PM
Dodge-My-Cummins
Err well i found Half gallon of DieselKleen in my garage closet so guess what i'm using......
Thanks for the help I just wanted to make sure it was safe to do so, I know in my cummins i just hold the filter under the spot where the fuel comes out then i pump the priming lever and fill it up that way. lol
Old Sep 20, 2010 | 06:55 AM
Otahyoni's Avatar
Otahyoni
First time i did it i used Diesel Kleen. This last time i used ATF. Had a little trouble getting it started back up, but it ran great after that...
Old Sep 21, 2010 | 08:30 PM
Dodge-My-Cummins
Thanks for all the help guys it turned out great, Cleared up all whtie smoke and made it run 100% better i couldn't be more happier.
I put on a Motorcraft filter and FILLED it with a full quart of Diesel Kleen.
it fired right up and didn't run bad at all, me and my buddy quickly pushed the shrader a little air came out then shot a stream !
i can't believe how much better it runs, we let it run for 5 minutes then took it out and floored it and it runs really well, not as slow as i thought. im sure the 4.10's help alot.....let it sit overnight then do the same thing tomorrow morning when i take it over to get the driver side seat sewed up
Now to stick a for sale sign in it!
waldrop4
313
Apr 18, 2026 11:50 AM
06greenstroker
6.7L Power Stroke Diesel
13
Mar 26, 2017 07:18 PM
Bubba Jones
31
Jul 2, 2016 02:06 PM
fballguy
23
Mar 20, 2016 07:27 PM
bflora
28
Mar 26, 2014 06:01 PM
