A lil Problem (pic)
Old Dec 9, 2012 | 01:08 PM
karjunkie's Avatar
karjunkie
A lil Problem (pic)
Old Dec 9, 2012 | 01:30 PM
79_FORD_F-100's Avatar
79_FORD_F-100
That looks very fuel efficient. Lol
Old Dec 9, 2012 | 06:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Well, that explains the rough idle.
Old Dec 9, 2012 | 09:04 PM
karjunkie's Avatar
karjunkie
and
the loss of coolant from the crack in between cylinders five and six on the head time ta start searchin
Old Dec 9, 2012 | 10:01 PM
rempel429's Avatar
rempel429
no problem, a little jb weld some bailing wire beer, good.. lol
Old Dec 9, 2012 | 10:05 PM
hairyboxnoogle's Avatar
hairyboxnoogle
That is a problem
Old Dec 9, 2012 | 10:07 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Pfft... that'll buff right out
Josh
Old Dec 9, 2012 | 10:09 PM
jetrinka's Avatar
jetrinka
That'd be a problem
Old Dec 9, 2012 | 10:22 PM
karjunkie's Avatar
karjunkie
haha
this is like comedy central just found a motor on cl for 400 buckaroos totally rebuilt w/aluminum intake
Old Dec 9, 2012 | 10:33 PM
earthquake68's Avatar
earthquake68
Sounds like a deal, but I'd still invest in a gasket set and tear it apart and check everything for yourself. Unless of course you can hear it run before you buy it.
As far as the old engine goes, ......yup. That's no bueno. Be sure to goop it good with silicone before you put that gasket back on. It looks like that one spot may be a little weak.
Old Dec 9, 2012 | 11:13 PM
karjunkie's Avatar
karjunkie
Ya, started with email ?s and well see from there
Old Dec 11, 2012 | 05:41 PM
Scifi266's Avatar
Scifi266
Esta no Bueno, just new head gasket time lol
Old Dec 11, 2012 | 08:28 PM
quadrazer's Avatar
quadrazer
If she blew out that bad, I'd have those heads and the block checked to see if they are truly flat....or have them decked (machined). Chances are something may be warped. I'd hate to see you throw time and money into a set of gaskets just to have it happen again.
Old Dec 11, 2012 | 08:46 PM
karjunkie's Avatar
karjunkie
The head that was on top of that gasket is bad (cracked between cylinders 5 and 6) so time to weigh in my options
Old Dec 11, 2012 | 10:55 PM
jetrinka's Avatar
jetrinka
Check craigslist. I see used heads and engines around my area all the time for less than 200 bucks.
