need to replace the EOT sensor
Old Dec 8, 2012 | 08:04 PM
hoytfan99's Avatar
hoytfan99
Is this a job that I can do or is it a job for a dealer. the truck is a 05.
Old Dec 8, 2012 | 08:08 PM
BLADE35's Avatar
BLADE35
You can do it easy
Do you know where it is????
I take it No since you are asking about it but its easy Peice of cake hang on I will post a Pick of location
Old Dec 8, 2012 | 08:10 PM
BLADE35's Avatar
BLADE35
here ya Go
Take the Oil Filter Cap Off or just so the oil filter housing Drains then you will limit the amount of Oil Loss during sensor swap
How do you know its Bad??????????????????????????????????????????????? ????????
Old Dec 8, 2012 | 10:34 PM
VQT's Avatar
VQT
Blade
Tried to Rep you but can't
Old Dec 9, 2012 | 04:25 PM
hoytfan99's Avatar
hoytfan99
after 12 hours sitting the oil temps are 14 deg. more than oil and water.
Old Dec 9, 2012 | 04:35 PM
Misky6.0's Avatar
Misky6.0
Depending on outside temps it may take longer
than 12 hours to settle.. i find on mon morning
my oil, coolant, and trans temps are within
a couple of degrees of each other.
Old Dec 9, 2012 | 06:44 PM
BLADE35's Avatar
BLADE35
I find the same in the A.M. morning temps are the same within 10seconds after startup
Well now that its winter 12 hours is usually enough
My truck is Thuroly cold soaked after 8 hours now
Its summer that takes longer to cool everything off and get a Good thuro cold soak
Old Dec 9, 2012 | 06:51 PM
69cj's Avatar
69cj
Lost you on this statement?
Old Dec 9, 2012 | 08:47 PM
RideDiesel88's Avatar
RideDiesel88
14* more than coolant?? Is it 14* outside??
Old Dec 10, 2012 | 06:51 AM
hoytfan99's Avatar
hoytfan99
I only drive my truck once every 2 weeks or so. The oil temps are always 12* to 14* degrees more than the others before I start up. I use my scan gauge to check them.
Old Dec 10, 2012 | 08:38 AM
69cj's Avatar
69cj
EOT, ECT and TFT should all be within a degree or two after sitting all night. Either the gauge is programmed wrong or you have a bad sensor.
Got Rattle
May 29, 2012 10:05 AM
NauticaEE
Nov 12, 2011 04:10 PM
mudbug04
15
Jul 16, 2009 03:48 PM
Jayc
Apr 7, 2006 07:15 AM
