Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Cobalt Drill Bit questions
Old Dec 7, 2012 | 11:17 PM
oldcoupe42's Avatar
oldcoupe42
I've used my Craftsman Cobalt tipped drill bits to bore out hardened steel rivet heads with great success, but I eventually broke or over heated some of them.
My question is who makes the best cobalt drill bits? I bought a cheapo over-sized set off ebay and they were terrible.
Is there a way to measure the Cobalt content and how much is the right amount? (I have seen some claim as high as 18% Cobalt), is that good?
Thanks in advance, Chet
Old Dec 7, 2012 | 11:49 PM
fixnair's Avatar
fixnair
You could buy a drill doctor and resharpen your dull bits. I don't us a droll doctor, I sharpen mine by hand on a grinding wheel. That works well but it takes years of practice to become skilled at it.
Old Dec 8, 2012 | 01:18 AM
Ford_Six's Avatar
Ford_Six
At that point, a masonry bit might be a good idea. Run it at high speed without lubricant until it glows, and it'll burn through what you're drilling. It does not make a clean hole though, and is slow going.
Old Dec 8, 2012 | 11:00 AM
oldcoupe42's Avatar
oldcoupe42
Thanks Ford_Six, you've helped me sooooo much in the past with all of your tips, but I've become spoiled by these expensive cobalt coated bits for doing jobs like my front coil spring mounts and rear leaf spring mounts and they cut through rivits like butter very quickly. Im just trying to find some low cost quality replacement bits for the Craftsmen Cobalt ones I ruined.
Old Dec 8, 2012 | 01:56 PM
Ford_Six's Avatar
Ford_Six
Low cost and quality don't usually go hand in hand. If you're set on cobalt, then go to your local Fastenal and see what brands they carry.
Old Dec 8, 2012 | 03:34 PM
khadma's Avatar
khadma
Carpenter Local 745
Since I have an ACE Hardware store just a quarter mile away from me,
and I usually need to pick up a bit in a hurry, I buy Irwin brand cobalts
for my steel drilling needs. I usually buy a single specific bit for my needs.
These seem to work great. Irwin step bits also seem indestructible.
Old Dec 12, 2012 | 10:53 AM
daveengelson's Avatar
daveengelson
My experience has been the Irwin cobalt bits tend to hold up longer than the standard hardware variety cobalt bits, pay more but at least the bit last longer than it takes to cook a 3 min. egg.
Old Dec 13, 2012 | 03:23 PM
Beechkid's Avatar
Beechkid
I agree with the others.....Irwin (I just don't spend the time to re-sharpen my drill bits anymore)
Old Dec 13, 2012 | 03:43 PM
daveengelson
I have used DeWalt and they probly hold up bout as well as the other brands. The Irwin seem to hold up better for me than some of the other brands. Bosch makes cobalt drill bits, I have not priced or tried them but been told they hold up very well.
Old Feb 15, 2013 | 06:32 PM
monckywrench's Avatar
monckywrench
If you have an acetylene or oxy-propane torch with a small heating tip (cutting torch tips work too, just don't tap the oxygen lever) you can make the "hard" rivet into a soft rivet.
You can also "wash off" rivet and bolt heads with a torch. Practice on scrap first.
Old Feb 16, 2013 | 06:49 AM
JWA's Avatar
JWA
I'll go slightly against the conventional wisdom here, suggesting maybe look into the Champion brand of drill bits: Champion Cutting Tool Corp. They don't call them "drill bits" though, industrial twist drills is their name of choice.
I've used this on different grades of rivet heads, SS screw/bolt heads and they're pretty amazing for what we'd consider plain ole drill bits.
I don't sharpen mine and for the most part they don't wear out under normal conditions. I've lost, broken or damaged them which isn't a lack of quality on their part.
If cobalt coating is your preference maybe shop online a bit? Even Irwin or DeWalt stuff can be found for less than what's in the local outlets.
HTH
78fordranger
Jan 29, 2009 06:17 PM
200000+F150
Garage & Workshop
15
Jan 6, 2007 10:01 AM
mzimmers
Garage & Workshop
Apr 6, 2006 06:25 AM
BodieBell
Feb 10, 2005 08:12 PM
72stepside
Garage & Workshop
Apr 23, 2004 05:51 PM
