Yes, if it significant. Low/no compression would mean the combustion would bypass the cylinder or rings and end up in the crank case, which would shoot your oil cap in the air. If everything is good, then the combustion is held in the cylinder (compression) and will exit out the valves like it's supposed to.
That is unless you have a large hole in the side of the block, but I'm guessing you wouldn't be asking about compression if that were the case.
I dont think that oil cap for compression test would work for leaking exhaust valve but should be a indicator of compression loss at cylinder as in piston ring & cylinder wear.
If it was a dually I would of already bought. Offer 5K and see what happens. Sounds like it needs injectors for some reason but it could be alot more or less.
you know it BONANZA...offers' on the table. If anything, dunp my motor in it, and install this motor into mine, and re-coup the difference...Cant beat a crewcab
from what we can see in the pics it looks like everything is original under the hood.
he cant find the leak so you know what that means... pedestal or hpop more than likely...
injector orings and the "tugly stick" disorder maybe for the smoke and miss?
and yes im referring to a loose injector when i say "tugly stick" disorder.
could turn that into a hell of a nice truck scoopin it up for 5k.
hope you get it brother!
