Low Compression #7
Old Dec 26, 2004 | 02:10 PM
Cfdchf's Avatar
Cfdchf
Low Compression #7
I have a 90 302 that is missing on Cyl #7 I have changed the Plugs, Wires, Cap, And iniector.It is better but still not right. So I just checked the Compression on that Cyl and it is 20psi It does not smoke or use oil So can I assume it is a valve and not a Ring problem.
Old Dec 26, 2004 | 05:47 PM
MustangGT221's Avatar
MustangGT221
Did you pour a little oil down the spark plug hole when you did the compression test to see if anything changed?
Old Dec 26, 2004 | 06:32 PM
Cfdchf's Avatar
Cfdchf
Yes I did it again with a teaspoonfull of oil or so and it came up about 10psi.
Old Dec 26, 2004 | 07:04 PM
MustangGT221
It's hard to tell, but something isn't right...it should be burning oil between a 3000 mi change if the rings are that bad. I had bad compression in a cylinder and it would only puff smoke between a shift change (my buddy driving behind me commented on it) and i'd never have seen/noticed it. I used about 1/2 qt between changes. It was a damaged cylinder and not the valves.
