302 w/ low compression
Old Jan 11, 2016 | 12:12 PM
Brandon Brunk's Avatar
Brandon Brunk
I need of some help... just bought a 1984 f150 w/ 302 and auto trans about 3 months ago. Out of the blue yesterday I decided to do a compression test on my truck. The passenger head was 110 all the way down but when I got to the driver head the first cylinder was 65 and the rest was 110 or 115. So im wondering what might cause this. Possibly a valve seal??? I also have a problem with the engine blowing oil out the breather on the driver side. Im wondering if its possible that those two things are related because the oil isnt a steady stream, it comes out in short burst. Thank ypu in advance
Old Jan 11, 2016 | 12:38 PM
Rusty_S's Avatar
Rusty_S
The two are related, bowing oil out of the breather and low compression on cylinder #5 would tell me you have bad rings on that side. I bet if you take the filler cap off and run the engine I bet you would get puffs of smoke out of the cap from the blow by in cylinder 5.
Old Jan 11, 2016 | 01:48 PM
Franklin2's Avatar
Franklin2
If it's puffing, it's usually a broken ring. That sparkplug should also be very oily/dirty.
timmyboy76
Dec 7, 2012 08:43 AM
geodiggr
Dec 2, 2009 05:40 PM
Marc150
13
Sep 3, 2005 10:40 PM
Cfdchf
Dec 26, 2004 07:04 PM
