Timing?
Old Dec 6, 2012 | 06:33 PM
phoenixfordf250's Avatar
phoenixfordf250
Timing?
I have a 79 f250 w a 460 I replaced the distributor with an HEI & new plugg wires. What should my timing be at in degrees +/-. I have strait pipes w/ high flow headers, edelbrock 4brl carb, and the engine was rebuilt about two years ago.
Any help wld be great
Old Dec 7, 2012 | 04:19 AM
Filthy Beast's Avatar
Filthy Beast
The timing for an HEI ain't no different than the stock dist. Check your bible for the degree setting. Might be different if you have a 'other than stock' cam, though.
Also, with an HEI dist, you can set your plug gap 10 (or so) thousands wider due to the higher than stock voltage.
Old Dec 7, 2012 | 03:19 PM
jeff14346's Avatar
jeff14346
8-12 inital, I have HEI in my 390 have plugs gaped at .050, love how the set up works
darthice
62
Oct 5, 2010 03:02 PM
j_crista
13
May 1, 2010 12:10 AM
wild bill pbr
Jun 6, 2007 06:26 PM
maples01
17
Feb 12, 2006 06:37 PM
Opiewan
Jan 3, 2004 07:26 PM
