I have a 1965 F100. Supposedly, it has a 390, but the engine is stamped 352. My question is....... How bad is it to have the timing too far advanced? The truck has new plugs and wires, and all vacuum lines are intact. I checked and regapped the points, and rechecked them with a dwell meter. Everything looked good, until........ I went to set the timing. The chilton manual says to gap the plugs at .034, the points at .017, and set the timing at 6 degrees BTDC @ 550 RPM. When I used these parameters, the truck starts hard and idles rough. I reset the timing to almost 20 degrees BTDC which seemed to help, and adjusted the carburetor. It still runs rough, and I am afraid that I will damage the engine with the timing set this way. Also, I replaced the plugs with a set that is one heat step higher because the old ones were carbon fouled. I have only had this truck one month. It ran fine when I got it. When I initially checked the timing it was set at 12 degrees, but now, even at that setting it runs like crap. Can someone please help me understand what to do with this and how to fix it. Any help would be greatly appreciated!!!! Thank you.
did you unhook the vac. advance when you were setting the timing? be sure and check the advance springs and weights in the distributor. they are prone to sticking. clean them up and put a little oil on the pivots. all the f e blocks are stamped 352.
Thank you Jim. Yes I did disconnect and plugged the vacumm at the distributor. I believe that everything inside the distributor is functioning fine but I will double check to be sure. @20* BTDC I'm getting plenty of high end power (65 to 80mph in no time flat). I really am worried though about burning up my valves or any other damage that might occur because of the advanced timing. I m going to pull the new plugs and read them. Maybe that will give me an idea about the timing and carb settings/condition. Also I'll try the old coat hanger to find #1 TDC then see where my rotor faces and what my timing marks say. Thanks again Jim.
what's the pencil or coathanger theory... is that when u take out the number one plug and rotate the engine by hand... Are u using a pencil to feel the air.
No Ray, the pencil, wire is used to measure the stroke. Feeling the air (compression) is a trick used to find compression stroke on number 1 cylinder. After you have determined the engine is on the compression stroke (air prssure as the piston comes up), use the TDC mark on the vibration damper to set it at TDC (assuming the damper is correct). Then set the distributor so the rotor is pointing at no 1 post on the dist cap. This will get you in the ballpark. Best way is mark the rotor position before you pull the dist, and don't turn the engine over with the dist out.
William in Atlanta
William in Atlanta
I have the same problem with my 66 inline 6cylinder. The distributor was removed when I got the truck. The engine had been turned over without distributor. How do I reset the timing/find out where the distibutor should be set? I got the truck running, but very rough
Kenekeg: Found what worked for me in determining timing and rotor position is to place finger in #1 plug and turn the engine over and compression forces finger out, at which point, the timing marks should be on, or near, TDC, and the rotor aligned with #1 plug wire on the distributor cap. I am not familiar with 6 cyl. distributor positioning. Having said that, with the timing mark on TDC, then should be able to install, or reposition the distributor gear to where the rotor aligns with #1 plug on distributor cap. Perhaps more knowledgable member can provide input. Purchased a couple of cheap tune up tools found comes in handy; a remote start button, the type that connects to the battery and starter relay. The other tool is an inline spark test light where spark plug does'nt have to be removed. Thus, able to perform a quick check from under the hood, if marks are within ball park the engine should run and able to fine tune. Any adjustments to fuel mixture then best to recheck the timing. As noted, it's just a 'quick check' and only take a few min's.
I can't remember if it was here, or somewhere else I read this, but I was having a terrible time setting the timing on my 66 with a 240 (and owning an aircooled VW, I'm VERY familiar with setting timing). The piece I read said that as an engine gets older, you might need to set the timing advanced a couple degrees, and I think it was because of wear in the distributor shaft. I followed that advice, and the truck ran perfectly after that.
