Sponsored by: Real Truck
Monroe Reflex Vs Magnum
Old Dec 4, 2012 | 07:36 PM
Ford Fx4's Avatar
Ford Fx4
Question Monroe Reflex Vs Magnum
Time for shocks, Got it picked down to the Reflex or the Magnum
On Monroe's web page there shock selector shows ...
"Durable Hard Working" ----For the Magnum
"Improved Stability with reduced harshness" ----For the Reflex
Truck is used for Hauling, towing about 8,000 pounds and plowing in the winter ( if it snows any time soon...)
Any feed back on either of these?
Thanks guys!
Old Dec 4, 2012 | 09:31 PM
Buck268's Avatar
Buck268
Bought my truck with newer Reflex shocks on all four corners, so I've never driven it with anything else. Now I have a F250SD with the short wheel base so I understand its a pretty rough ride, especially since its virtually unloaded 100% of the time. BUTTT these Monroes seems to ride like crap. I'd expect the rough ride with hard jolts but these shocks seem to offer very little rebound dampening so what little suspension compliance I DO get just fires the chassis back up explosively.
But like I said, I've only had these shocks on here so I cant compare.
Old Dec 4, 2012 | 10:37 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I have Gas Magnums on my truck now and they work great but I had the Reflex on before and they didn't do the job when pulling loads or running empty.
Denny
Old Dec 5, 2012 | 06:16 AM
SDTriton250's Avatar
SDTriton250
I've owned both on my previous Rams. I liked the Gas Magnums better. The Reflex did what they're supposed to do. Firm but open up on the bigger bumps. For me that meant making the little road irregularities seem bigger. A 3/4 ton pickup doesn't need any help making the ride rougher. The Gas Magnums give a softer ride while doing their job well on the bigger bumps. Especially while towing our 5th wheel. At 52k miles, my F250 isn't far from needing a set of shocks. I'll be going with the Gas Magnums.
Old Dec 5, 2012 | 10:16 AM
Ford Fx4's Avatar
Ford Fx4
Thanks guys,
I think I'll go with the Gas Magnum and see how I like them.
I Was also looking at Rancho's too, but it looks like they are both made by Tenneco anyways....
Old Dec 6, 2012 | 09:41 AM
abranz's Avatar
abranz
I put the yellow magnums on my Ex and they're fine, not to harsh. A plus is the lifetime warranty.
Old Dec 6, 2012 | 02:31 PM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
Yep Tenneco is our parent company, we will have difference from brand to brand though. Valving/pressure/sizes etc. Enjoy!
Originally Posted by Ford Fx4
Thanks guys,
Old Apr 12, 2013 | 08:22 AM
Buzzard_Wing's Avatar
Buzzard_Wing
I just ordered the Gas Magnum from Rock Auto and they showed up less than 24 hours later! In small letters on the box it says 'Made in USA'!! You would think Monroe would promote that fact.
The old bed is on the way to the scrap heap and I am going to 'paint' the frame, figured it's a good time to swap the shocks too. A bit puzzled by the rear shock mount, seems there is no 'drain'? I will get a closer look tomorrow.
Found the suspension/ride on the SD much better than my 95 250. I liked the Rancho 9000's on that one, especially with a camper in the bed.
BlackBeest
6.7L Power Stroke Diesel
30
Aug 2, 2014 12:46 PM
jblueguy
Apr 20, 2013 11:16 PM
Johnny Yarbrough
1978 - 1996 Big Bronco
Jun 29, 2008 12:21 AM
76 F250 4X4
Sep 13, 2004 02:16 AM
Chuck4184
Apr 15, 2004 04:48 PM
