Sponsored by: Real Truck
ABS Light on
Old Dec 4, 2012 | 04:23 PM
British Bulldog's Avatar
British Bulldog
ABS Light on
Hi all, I have a 2002 4X4 F350 Dually. a few months ago I had to replace the 4 ball joints on the front hubs ie 2 per side upper and lower. I didnt do the work I put the truck into a garage for the work to be done, I just didnt have the time to do the work myself. ( first mistake) When I got the truck back the ABS light was staying on, I guess due to the fact that the front hubs were removed off the truck. I have inspected the ABS wireing and see no damage. Is the fact the light is staying on due to the fact that the ABS sensor parted company so to speak on hub removal, and if so how do I turn the ABS light off. I have gone to various garages and noone seems to have the right scanners to reset the light, obviously due to the fact I live in the UK.
Is it possable to turn the light off by removing the batteries like a hard re boot? any help with this issue would be a great help as info this side of the pond is scarce and none existant. Also if a Scanner is needed for the job which one would you guys reccomend.
Many thanks.
Steve
<!-- / message -->
Old Dec 4, 2012 | 05:01 PM
Lou Braun's Avatar
Lou Braun
You would need to get a scanner that reads Ford ABS codes. I user an Innova 3160 and it has reliably read, and cleared, all of the ABS codes.
From your description, I would suspect one of the front wheel ABS sensors got damaged during the hub and ball joint repair. You would need to read the exact ABS code to pinpoint the offending sensor.
Lou Braun
Old Dec 7, 2012 | 06:27 PM
British Bulldog
Thanks for the input, as suggested I have bought a scanner that reads all codes plus all ford ABS codes..hopefully this will narrow the problem down to which front wheel is faulting. will keep you posted.
Old Dec 8, 2012 | 09:16 AM
crazyrwe's Avatar
crazyrwe
Is it making a growling type of sound when steering? When my sensor went it would as soon as i turned the wheel left.
Old Dec 8, 2012 | 07:37 PM
delgriffith's Avatar
delgriffith
From what I recall, the ABS light isn't like the check engine light where it needs to be cleared. If you fix the fault, it will go out on it's own. Same as the airbag light.
Old Dec 8, 2012 | 09:10 PM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
I had the same problem with my wifes 98 Expedition. Turns out it was a bad wheel sensor. $65 for new sensor and problem fixed.
Jaaaaaaackman
Dec 27, 2016 12:34 PM
Trevor.801
Jan 10, 2015 04:55 PM
rb8484
Feb 5, 2009 04:47 PM
DieselJr
Oct 17, 2008 09:35 AM
Gmeanie
May 15, 2008 01:27 PM
