Sponsored by: Real Truck
ABS help
Old May 13, 2008 | 10:50 AM
Gmeanie's Avatar
Gmeanie
ABS help
Well finally finished the ball joint repair but now my ABS light stays on?
It was a pain to get the abs out and I noticed some of the copper wire was loose. So I cleaned it and tried to squish some of the few strands of copper that was loose back on. But now the ABS light won't go off. When I start the truck it blinks off once and comes back on? Called to replace the part and the want $150.00 ouch!
Anyway to fix it or just get it to shut off. I hate ABS anyways.
Old May 14, 2008 | 08:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If the light is on, the ABS isn't going to do anything
When you say "get the abs out" what did you remove? The valve unit? Or the sensors in the hubs?
Sounds like one of the hub sensors is bad, bad connection, bad connector, something.
Old May 15, 2008 | 09:51 AM
Gmeanie's Avatar
Gmeanie
The sensor in the front hub.
Is there a cheaper after market sensor out there?
It was working before I took it apart so I know it must of got screwed up trying to get it out.
Old May 15, 2008 | 01:27 PM
jbrunel's Avatar
jbrunel
I have a known good sensor I pulled from a wheel bearing hub job..If your interested lmk
edsheridan
Aug 25, 2014 02:39 PM
redsly
1997 - 2003 F150
Jul 10, 2012 07:39 AM
BluegrassPicker
15
Oct 10, 2011 10:17 PM
v8xploder
1978 - 1996 Big Bronco
Jun 25, 2011 09:18 PM
kittyhawksurf
Jul 7, 2009 07:28 AM
