Cam Issue?
Old Dec 3, 2012 | 08:27 PM
Action4478's Avatar
Action4478
Originally Posted by fsr_7
Pulled that spring out and it was not attached to the triangular piece behind it - My spare assembly these two pieces did seem attached, threw the spring in from the spare assembly and its still not building fuel pressure while cranking.
We've actually had 3 CPS ' s in the truck since it started acting up - the new one I purchased was off brand, the new one the owner had purchased I'm not sure where it came from. I'll get one from ford tomorrow and try it, if the off brand ones are so notorious for being garbage. Keep in mind, when the truck would run but stall constantly, the symptoms were identical with all 3 CPS's.
Keep the ideas coming... much appreciated...
MY wag is a sticking IPR ....If you have a scanner & DVOM , we can test the IPR...
Old Dec 3, 2012 | 08:38 PM
fsr_7's Avatar
fsr_7
I have access to a scanner on occasion. I have a spare IPR here now. Is there a good sticky or link to what to look for on the scanner? I had it hooked up when it first started acting up, but really didn't know what I was looking for - we buzzed the injectors and a couple other generic tests that didn't reveal anything problematic. It wouldn't take too long to swap the spare IPR - I'm getting pretty proficient at taking that stupid fuel bowl out
Old Dec 3, 2012 | 08:44 PM
Action4478's Avatar
Action4478
Try the Spare .. 20 minutes . Cheap test ...
Old Dec 3, 2012 | 08:48 PM
nomad221's Avatar
nomad221
Another WAG, is the fuel tank selector valve operating properly ? Could be the reason for low fuel pressure.
You could pull it and bench test it with a 12V source.
Old Dec 3, 2012 | 08:52 PM
nomad221's Avatar
nomad221
Don't have to pull the bowl but it takes a little work (and patience) to get a wrench in to loosen the tin nut. Sorry, I don't remember the size.
Old Dec 3, 2012 | 08:58 PM
Action4478's Avatar
Action4478
One fuel line out of the way is all you need . Loosen the 2 bowl bolts will help ...
Old Dec 3, 2012 | 11:09 PM
fsr_7's Avatar
fsr_7
Spare in, no dice. Still less than 10 PSI cranking at the shraeder. Don't I need fuel pressure for this thing to fire? I feel like replacing CPS/IPR/other sensors isn't going to fire it if the symptom is low fuel pressure. FSV worked spot on when we were cleaning the lines - I'm more of an IDI guy and I've seen the FSV's fail on those trucks, usually fairly obvious. Back to the original question - why can't I get more than 10psi out of the valve? isn't that necessary for these beasts to fire?
Ambulancewarrior
21
May 16, 2019 12:24 AM
mark460
Feb 13, 2015 09:43 PM
6.9lXLTf250
13
Jul 12, 2010 12:28 AM
joe f350
19
Jul 31, 2009 03:48 PM
