O'Reilly's Lift Pump
Old Feb 13, 2015 | 01:26 PM
mark460's Avatar
mark460
I'm working on a 1990 7.3 IDI which has a bad lift pump. I should have known better, but I bought a pump from O'Reilly, it is the "precision pump" brand. Anyways, I put the pump on, got the truck running, cut it off the night. The next day went to try to start and it wouldn't. Found out no fuel was coming from the pump, checked everything, found out the new lift pump isn't working. Pull it off and verified it is not pumping. I can't think of anything I could have done wrong. Anyone recommend another brand? Carter maybe? Thanks
Old Feb 13, 2015 | 01:33 PM
genscripter's Avatar
genscripter
Can you post some numbers of the pump? flow? Pressure? I think most of those off the shelf pumps are not rated for Diesel and have only a few PSI.
If you want a good pump, order a Duralift from that dude .... I can't remember his username. He's on FTE. Let me try and find him.
Old Feb 13, 2015 | 01:47 PM
genscripter
Found him. "Genlightning"
https://www.ford-trucks.com/forums/1...l#post13719229
Old Feb 13, 2015 | 01:49 PM
mark460's Avatar
mark460
According to the website, part number is M23003, flow is 30gph, pressure is 5.75 psi.
The engine is stock and will probably stay that way.
Old Feb 13, 2015 | 02:05 PM
genscripter
It's been a while since I've replaced my pump, but I think the IDI requires a 7-9 psi rating minimum. 5.75 is probably too low.
Old Feb 13, 2015 | 04:34 PM
madpogue's Avatar
madpogue
The Carter and Airtex pumps for this truck spec out exactly the same. In fact the pic for the Carter pump on RockAuto is exactly the same as that for the Precision Pump on oreilleyauto.com . The pump is made to physically fit the engine, with an arm length designed to interface with the cam lobe. Given that it's built to this purpose, it's unlikely that it's not rated for diesel, or that it's underrated to supply the IP.
Most likely an "infant mortality" part. Looks like O'Reilly has the Spectra pump for this application, SP1010MP , for a few dollars more. Dunno about the pumps, but Spectra's fuel tanks have a good reputation. Might be worth asking to look at each one on the bench out of the box, and if it looks like the Spectra is a superior product, get them to exchange it for the difference in price.
Old Feb 13, 2015 | 04:35 PM
Chevy_Eater's Avatar
Chevy_Eater
I'm not familiar with Precision, doesn't sound promising with your experience.
You want to avoid Airtex anything and sadly I understand Airtex now owns Carter; so much for Carter.
I think 5-6lbs for a mechanical lift pump sounds normal to me.
Old Feb 13, 2015 | 06:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
yea, 9 psi is kind of high. stock lift pump pressure is only 7 psi at filter head outlet with engine not running.
Old Feb 13, 2015 | 07:06 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
he no longer sells them.hasn't for a year or so now it seems.you can find them on ebay though.definitely the way to go.
Originally Posted by FORDF250HDXLT
7.3L IDI Turbo Diesel Engine Performance Specifications
Engine Model A-185, A-166
Number of Cylinders 8
Configuration OHV V8
Bore 104.39 mm (4.11 inch)
Stroke 106.20 mm (4.18 inch)
Displacement 7.3 Liters (444 cu inch)
Crankshaft Rotation (Viewed from
Flywheel End of Engine) Counterclockwise
Compression Ratio 21.5:1
Firing Order 1-2-7-3-4-5-6-8
Idle Speed (No Load)* 650 rpm ± 50 rpm
Governor Speed (No Load) 3660 ± 50 rpm
Governor Speed (Full Load Rated) 3000 rpm
Timing (Dynamic) 8.5 ± 2 Degrees BTDC
Injection Pump Stanadyne DB-2
Injection Nozzle
Opening Pressure (New) 13,100 ± 517 kPa (1,900 ± 75 psi)
Opening Pressure (Minimum) 9,998 kPa (1,450 psi)
Crankcase Pressure-No Load (Maximum) 20 kPa (6 in-H2O) @ 3000 rpm
Fuel Pressure (Filter Inlet) 14 kPa (2 psi) @ idle
Fuel Pressure (Filter Outlet) 7 kPa (1 psi) @ 3000 rpm
Fuel Pump Suction 20 kPa (6 in. H2O) @ 3000 rpm
Fuel Return Line Pressure 14 kPa (2 psi) @ 3000 rpm
Valve Lifter 0
Valve Lash
Engine Lube Oil Pressure
Low Idle, Minimum 69 kPa (10 psi)
(Engine at Operating Temperature) 276-482 kPa (40-70 psi)
Crankcase Capacity (Without Filter) 8.5 L (9 qt.)
Crankcase Capacity (With Filter) 9.5 L (10 qt.)
Thermostat Opening Temperature 89°C (192°F)
* Manual transmission in NEUTRAL position. Automatic transmission in DRIVE position.
Old Feb 13, 2015 | 09:43 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Above is right, no mechanical pump moves more than 3-4psi that ive ever seen except for like the holley red/blue mechanicals, and theyre like 5-6. 6psi is more or less the ideal pressure according to the pump stand.
rodymartin
Feb 23, 2014 10:42 PM
nofishbob
Feb 14, 2013 06:26 AM
bio-d
May 10, 2007 10:03 AM
Orezona
Apr 24, 2007 09:28 PM
John311t
Nov 16, 2006 01:08 AM
