MBRP 4" - Self-install how bad?
Old Dec 2, 2012 | 03:18 PM
fishintheobx's Avatar
fishintheobx
Question MBRP 4" - Self-install how bad?
Due to the overwhelming support of the MBRP system on this board, my 4" Turbo-back complete with Test pipe is in the mail on it's way. I hadn't planned on doing this until next year, but it looks like the truck is going to put on about 2500 miles over the Christmas holidays (1000 will be towing 6k lbs), I decided it was a good time to get it done.
How bad is this to do by myself on the 6.0? I don't have any help right now. But it seems the universal advice is to cut the old downpipe before removing. Any other pointers? How tight are things around the turbo?
Old Dec 2, 2012 | 04:03 PM
X-Hibition's Avatar
X-Hibition
I had the luxury of a hoist so I popped the down pipe out in one piece, but yes, everyone doing it on the ground cuts the pipe.
Since the original install I have replaced the muffler clamps with stainless steel band clamps from NAPA. I've been back and forth many times with cat delete and muff delete pipes and it is all very easy using the band clamps.
So the install is easy and swapping parts is easy. Especially in Florida weather...
Old Dec 2, 2012 | 05:41 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Not very hard to do....
-Have a sawsall handy.
-Remove the right rear lower shock bolt and let it dangle. It'll make removing and installing alot easier.
Old Dec 2, 2012 | 06:45 PM
fishintheobx
As in the bottom of the shock that connects to the axle? I did this when I installed my Helwig, and while I cussed it something fierce getting it compressed back up, I did get it.
X-Hibition: this is the time in FL we do the outside work, because come late April it's so hot / humid you'll do anything to avoid crawling around under an Ex! Will definitely go with the bands from Napa to help the process.
Old Dec 2, 2012 | 07:00 PM
Toreador_Diesel
Correct!
You might even come up with a few curse words too
Old Dec 2, 2012 | 07:05 PM
fishintheobx
No shortage of that around here
Thanks for the help...
Old Dec 2, 2012 | 11:15 PM
hink10's Avatar
hink10
What they said! I did it once before, not bad. It was one of my first mods and didn't have too much experience. My last one was done by a shop, can't do that stuff any longer.
Old Dec 3, 2012 | 03:57 AM
kornfanjoe's Avatar
kornfanjoe
It's also a good idea to set everything up loosely so you can adjust and position it as needed then tighten everything up!
Old Dec 3, 2012 | 10:00 AM
TinMan289's Avatar
TinMan289
+1
I haven't done one of these installs yet, but from my experience installing a few exhausts on mustangs and the like, this is the most valuable information going! You really get to line everything up and get it where you want it while it's dangling.
Old Dec 3, 2012 | 10:02 AM
jeeplj8's Avatar
jeeplj8
couple of pointers from mine:
Many Ex's have a huge heat shield wrap on the downpipe. this is there for two reasons, heat and noise. the heat shield itself is what made the downpipe hard to remove. We had to cut the heat shield off then cut the downpipe to get it out. that truly is the largest PITA in the whole process. I pulled mine off after a few days and wrapped the new downpipe with header tape and it helped both noise and heat.
When tightening, don't forget to start at the turbo and work back. I forgot and had a vibration issue and had to go through and loosen it all up again. It helps to have two people, one to hold the bottom side of the downpipe in position while someone tightens up at the turbo.
an 18v impact is worth it's weight in gold underneath.
Old Dec 3, 2012 | 06:11 PM
fishintheobx
I noticed that! Since I don't want to incur any more heat or noise in that area than possible, I have considered the same. Not a big fan of header tape, so I put in for a price quote to get thermal ceramic coating down on the downpipe from Jet-Hot. We'll see...
Old Dec 3, 2012 | 06:33 PM
archtaan's Avatar
archtaan
The only hard part is getting the old clamp off of the turbo and reattaching the new down pipe, its just a bit awkward. Besides that just have a good size breaker bar or screwdriver to help pop the old hangers out of the rubber isolators. A good bit of spray lube is your friend here.
If you arent going to reuse the parts or resell them, just cut them off. Its a lot easier than trying to separate them.
Old Dec 4, 2012 | 07:43 AM
fishintheobx
Yeah...the only thing that concerns me is working up around the turbo since things are tight. But I'll figure it out.
I'm going to pretty much take the Sawzall to everything. I'll keep the CAT, but other than that it's going to the recycler for some extra fuel $$!
Old Dec 4, 2012 | 08:44 AM
jeeplj8's Avatar
jeeplj8
this is the exhaust wrap I used:
DEI Titanium Exhaust Wrap with LR Technology 010127 - SummitRacing.com
I also used SS clamps to hold it on. It is wrapped very tight, and overlapped. Coming up on 2 years installed with no issues whatsoever.
Old Dec 9, 2012 | 08:29 AM
fishintheobx
Well...got it all done! It kicked me in the pants pretty good...feel like I played in the Army / Navy game yesterday. But I'm loving the new system. Was really concerned about interior noise. But I took my "noise detector" for a test ride last night and her conclusion was she can hear the difference, but it's really no worse than before at 75 mph. I jumped on it under an overpass and the pipes will definitely bark under hard acceleration.
The downpipe / turbo clamp came off pretty easily, but getting the new downpipe on was a different story. Not easy, but I figured out if i slipped the clamp over the turbo first, mating up the downpipe went easier since it's flange was smaller. PB Blaster helped the rubber hangars slip out better. I cut the downpipe in front of the x-member, and the pipe in front of the axle to make things come out easier. Life also got a little easier when I disconnected the right-rear shock from the axle.
Overall I'm pretty impressed how well that system mates up into the hangars, including the cat delete pipe I put on.
sdetweil
6.4L Power Stroke Diesel
21
Mar 28, 2011 08:24 PM
dave91gt
Nov 16, 2010 11:55 AM
Chuck U&R
Aug 26, 2008 02:17 PM
sicf250
Jul 5, 2005 04:00 PM
ltfox
Mar 2, 2004 11:15 PM
