'65 352 headers
Old Dec 5, 2012 | 10:18 PM
smokenchoken's Avatar
smokenchoken
also one major thing you need to worry about is certain headers will not work in certain applications my long tube 3" race headers will not fit in my 66 (well they will but the flange in right square in the middle of a cross member and neither can be moved....)
Old Dec 6, 2012 | 09:51 AM
ol yeller's Avatar
ol yeller
Real the starter in a heat shield. That header can cook the starter. I have a set for mine and plan on bolts breaking....
Old Dec 6, 2012 | 01:57 PM
The Masked Rider's Avatar
The Masked Rider
NOT CHEAP but I understand Sanderson has a set of headers designed for our 60s F-100 trucks. They collect and dump straight down between the two center cylinders on each side. They are shorties as they call them. Sure look nice. You can make your exhaust pipes to go around the starter so it doesn't cook it. I talked to a guy that made a small section of exhaust pipe from the header to just past the starter. This piece of exhaust pipe can be removed so the starter can be replaced easy if needed. Great idea since the starter can be a real pain in butt to change out.
slinger34
58
Aug 12, 2016 07:48 PM
doc66
Apr 13, 2009 07:20 AM
65steelstallion
Apr 24, 2008 12:12 PM
NeilK
May 15, 2006 11:28 AM
Ron_coach
Mar 19, 2006 03:51 PM
