hi guys and guru's,
my qeustion for the day, can i use the shorty cast iron headers on my 65 F100SWB with a 390 FE auto, pwr str, pwr brk?? will they clear everything. i have a chance to get a set real cheap if they will fit.
thanks for all the help to date.
I thought most of the cast header style exhaust manifolds for FEs had the straight across GT style bolt pattern rather than the over under.
I do believe you are correct. And I dont think those headers are going to come cheap.. but if you can get them cheap.. getm and ebay those puppies off for the $ to buy a nice set of Sandersons®
My guess is cast iron headers will NOT fit your 65 F100. Only because I looked at a 1969 F100 with an fe390 and cast headers. ( I think they have the same frame width ) The frame had been notched about 1 1/4" to clear the cast headers.
Redmanbob is right. I'v seen cast iron headers go for $500.00 a set.
