brakes that don't
Old May 23, 2003 | 01:09 PM
usmc_ford's Avatar
usmc_ford
brakes that don't
i am currently trying to run an '81 F-100 w/ I6 300 automatic, but the biggest problem is the lack of brakes. it loses fluid out of the front resivoir weekly and the pedal drops to the floor like the brakes are a joke... the vacuum lines are "ok" and the brakes lines are tight with no leaks, so do any of the wrench turners have clues as to what is tryin to get me killed? other than that it just blows out a reverse light bulb about once a month, i dunno - just gonna live with it for right now. gotta get it inspected first.
any help is appreciated.
Old May 23, 2003 | 04:22 PM
lumberjack61's Avatar
lumberjack61
brakes that don't
the front res. most of the time is for the rear brakes check that the wheel cyl are not leaking to do this you can look at the backing plate and see if it is "wet" or pull off the drums if not check the lines then the master cyl
Old May 23, 2003 | 04:53 PM
Franklin2's Avatar
Franklin2
brakes that don't
Yep, the fluid is going somewhere!
Old May 23, 2003 | 05:33 PM
steve83's Avatar
steve83
brakes that don't
Follow the rear brake line from the front port of the MC down to the frame rail and back to the crossmember just behind the rear axle. There's a brass union under your seat, so check it.
Mcroz
20
Sep 17, 2013 02:57 PM
Izera
1997 - 2003 F150
May 5, 2013 01:27 PM
allquieton
Nov 9, 2012 11:53 AM
79fordf250pickup
May 22, 2010 11:54 PM
akparker1
Feb 26, 2009 12:54 PM
