Multiple new problems
Old Dec 1, 2012 | 12:26 PM
DieselVol's Avatar
DieselVol
Background: AC serviced 3 months ago, head studs 2 months ago with new oil cooler and new thermostat at the same time. Truck has been loosing coolant lately, NOT through the degas cap for sure. Deltas have been a little higher than I would expect, usually 11-12 at the most. Yesterday again saw a pool of fluid under the truck. Apparently it is now low enough to affect cooling as deltas went as high as 31(!) on the way home this morning. Surprising to me is that ECT was not affected, only EOT, and it got to 224 at the highest. Also noted that the AC is not working. When I got home I filled the coolant up to the min line and the deltas dropped some, but only to the 15-20 range and the AC still won't work. Degas bottle pressures when full don't go over 8 and, after burping it, never above 1-2. Do the AC problems and the cooling problems go together? Any of this make sense in the face of all of the recent work?
Old Dec 1, 2012 | 01:50 PM
bismic's Avatar
bismic
Could your water pump be going bad and leaking?
Old Dec 1, 2012 | 02:44 PM
DieselVol's Avatar
DieselVol
Hmmm, good question. Water puddle is on the left side, toward the back of the engine compartment, and the u-joint of the front differential tends to be wet when I see a puddle. Sound right? Would that explain the AC problem?
Old Dec 1, 2012 | 04:20 PM
steelhead2's Avatar
steelhead2
Is your egr delete leaking?, i would look in the valley of the engine for coolant.
Old Dec 1, 2012 | 04:22 PM
bismic's Avatar
bismic
That area (left side being the drivers side) sounds more like it would be a crack in the degas bottle or a hose around the degas bottle.
Old Dec 1, 2012 | 04:25 PM
DieselVol's Avatar
DieselVol
That area sounds more like it would be a crack in the degas bottle or a hose around the degas bottle.
That's what I think too, but can't seem to locate it. I'm also going to look at the EGR delete as mentioned above. I can't seem to fit the sudden loss of AC into all of this. I know it worked just a few days ago.
Old Dec 1, 2012 | 04:26 PM
steelhead2's Avatar
steelhead2
Im with you bismic. I was picturing the engine from the front........you have access to a pressure tester?. A good way to find leaks like that is to pressurize it and start looking.
Old Dec 1, 2012 | 04:30 PM
DieselVol's Avatar
DieselVol
Now that I filled it back up, the next drive will pressure it up to 8-9 with the cap on. That will likely get 'er spewing. I'm guessing y'all don't see the AC issue as being logically related?
Old Dec 1, 2012 | 05:28 PM
bismic's Avatar
bismic
A/C problems can happen with a lack of circulation of coolant.
Old Dec 1, 2012 | 05:34 PM
DieselVol's Avatar
DieselVol
Then I'd say that's it. I was surprised from day one post head studs, when despite a new oil cooler and thermostat, my deltas still were around 9-11 and occasionally briefly out to 13, despite no load. That's pretty much what it was doing with the old stuff. While that is within normal limits, it seems to me to further out towards abnormal than I would expect with all new stuff.
Old Dec 1, 2012 | 06:16 PM
04badford's Avatar
04badford
I almost said heater core, untill steelhead made note . there is a hose down by the ficm and it presses into a bolt I had a leak there also under degus bottle are plastic fitting .
Old Dec 1, 2012 | 06:38 PM
DieselVol's Avatar
DieselVol
I feel confident that some degas bottle connection is lose or cracked. When the pressure comes back up, I should find it.
Old Dec 2, 2012 | 08:41 PM
DieselVol's Avatar
DieselVol
Update:
Even with adequate coolant in the degas bottle, deltas still get over 15 with easy (50 mph), unloaded driving. Still affecting only the EOT. ECT is normal (for my truck) at 192-196. After the degas bottle pressure got up to 9, there was coolant dripping off of the front u-joint and down the back of the bell housing. I can't pinpoint where it's coming from, but I suspect it is whichever hose that carries coolant to the oil cooler as it seems to be having a hard time getting cooled. Also, the AC still won't work, so I assume those 2 issues are off of the same hose, or at least one is down stream of the other. Back to the shop that did the head studs...
Old Dec 2, 2012 | 09:50 PM
04badford's Avatar
04badford
the hose that I was refurring to wraps around the back of motor and goes to the heater core, connections under the degus are plastic fittings ,did you pull the degus off and look real close also throw the ford clamps in recycle bin and get some real clamps on there , that hose is hard to see and there is a bolt right in the way I tyed mine back.Just a thought.
Old Dec 2, 2012 | 09:56 PM
DieselVol's Avatar
DieselVol
Good plan, it's just that I paid somebody to do the work right. If I start messing with it, I might get blamed for breaking something or causing some other problem. As it is now, I'm just a reporter telling him what happened. This SHOULD cost me nothing.
