Ignition lock removal
Old Nov 28, 2012 | 11:50 AM
Red-head's Avatar
Red-head
Red face Ignition lock removal
95 f 150, how can i get the key lock out and start the truck with a screwdriver? The key broke, but not in ignition. Im stranded need a quick easy fix guys!!! PLEASE
Old Nov 28, 2012 | 12:01 PM
Puddy's Avatar
Puddy
Need the key to turn the ign over to run then there is a small ball in the column that gets depressed , then the assembly comes out.
Sorry to tell ya but that's the only way,
Old Nov 28, 2012 | 12:39 PM
Red-head's Avatar
Red-head
Thank you for your reply. There has to be a way with a broken key.
Old Nov 28, 2012 | 12:55 PM
2002 F350V10's Avatar
2002 F350V10
pry off the chrome butterfly, and then you drill out the area where the key goes. dont go too deep. You pick the pins out and get the lock cylinder to turn , once turned to the on position, depress the small hole area directly under the lock cylinder from below. When depressed remove the cylinder, and install the replacement. Ive seen vehicles with the keys still in them at the pick a part yards sometimes. You might get lucky and get a used one.
Old Nov 28, 2012 | 01:03 PM
Red-head's Avatar
Red-head
I appreciate it. Sure thought there would be an eaiser way to get a screwdriver in there!! Looks like I'll be buyin a new lock & key. Now, to drill it right to get it out!!
Old Nov 28, 2012 | 01:57 PM
Puddy's Avatar
Puddy
Unplug your battery otherwise u may short the system.
Old Nov 28, 2012 | 01:59 PM
Lead Head's Avatar
Lead Head
If they key just broke off at the head, I suppose you could just put the teeth portion into the cylinder and mash it down with a flat head until it turns.
Old Nov 28, 2012 | 04:45 PM
Red-head's Avatar
Red-head
Yes very clever! Thank you! Although I believe my g-pa gave me the wrong spare key, that's how it broke in the first place. It started it all evening though. Pulled up to get gas, turned it off, it wouldn't turn back over. Before it broke at the base of the key, it would turn back to acc. That's why i figured i could pop it out & use a screwdriver! Without drilling!!
VolvoMatt
Oct 9, 2013 11:43 AM
DJdemon6696
Nov 20, 2008 07:30 PM
ruggles
Dec 17, 2007 07:54 AM
Chumbucket
Jul 13, 2007 08:38 AM
Jenners
Apr 26, 2005 01:28 PM
