Dual range transmission overdrive?!
I bought a parts truck yesterday, and when chaining it down I noticed the transmission had something on the tail end. I did some searching and did some research and it is a U.S. gear dual range ratio overdrive system. It shows that it is $2400 new! It's on a c6 2wd trans out of an 85 diesel. Anybody know why one of these are worth?!
This is the web sight I found...
DualRange Overdrive
Any help would be appreciated! Thanks!!
DualRange Overdrive
Did you read down far enough to see this on that website?
"They are completely out of production, no factory parts available at all. I am out of it. It's all junkyard and scrounging from individuals or shops who may still have stuff. Like as in old brownie boxes. Sorry. good hunting!"
How much does it weigh? That would be one way to determine value.
Or, maybe it has parts you could sell.
Does it work? Did you get a controller?
They will not shift without the control module. If you have everything then it is worth something.
Index of /temp/usgear
The US Gears unit is "obsolete" but that doesn't mean you can't use it. You can still find parts if you try, mostly cross reference stuff. You don't find hard parts like cases, or gears unless you find a unit for parts.
The fact that it's obsolete and doesn't have strong aftermarket support could severely hinder the value. Most people won't buy something they can't fix.
On the other hand, those who really want one will be willing to pay a higher price for it. There's something about the US Gear not having as many issues on hills as the GearVendors unit, so that may be a strong point.
That being said, I have seen them go from $300-$1200, depending on condition, complete or incomplete system, and whether or not they're rebuilt. Before you ever gain those prices, you'll have to deal with all of the "It's just a baby transmission, blah blah blah. It's only worth $50". It may sit on your shelf forever, or it may go within a week for a decent price.
If it is an underdrive unit, it's not the end of the world. Guys with higher gear ratios will love it for it's ability to increase torque. But you will probably see more interest if it's an overdrive unit, for obvious gas-saving and lower RPM reasons.
If you want to keep it for yourself, and you use it on the 80, you'd have to move the transfer case back, and have your rear driveshaft shortened, and front driveshaft extended. The US Gear unit mounts between the transmission and the transfer case.
Well, you can turn the input shaft and see if the output shaft turns faster or slower. However that would only work if someone left it in under/over drive. I don't think you can find out by the serial number, I doubt anyone still has the records.
I know they sold for over $2k new however there is a Doug Nash (similar to a US Gears model) on ebay, the DNE2 in very nice condition for $950 buy it now. I bought one before for $250 but that was cheap. You could probably only get $500-750 for it. However I don't even know if you have the US Gears model, Doug Nash model, or something else. US Gears bought out Doug Nash but now they are both out of business as far as I know.
WhatsAChevy?
10-08-2016 06:09 AM
Macs1964F100
11-23-2012 02:36 PM
superduty86
01-08-2012 09:57 PM
77460ford
02-07-2011 03:06 PM
