Questions for NumberDummy
Old Nov 27, 2012 | 08:29 PM
desertbus's Avatar
desertbus
Hi, NumberDummy. Casey here. You might remember me from a few years ago when I was looking for a set of 17.5 inch 6-lug Bud dually wheels to mount 8R17.5LT tires to. Grigg eventually helped me with much of that. And I found the rest of my needed wheels on Craigslist. And now I own a full and good set of seven of those wheels, three-holers all, plus a couple of six-hole bent ones for keeping in reserve.
Anyway, I'm hoping you can help me out. I wonder if I give you my chassis number off of my title whether you might be able to tell me about the origins and constitutionals of my heap, a 1962 Ford F350 dually with a 292 manual tranny. So here's the chassis number...
F35CR260617
Also, sir, I wonder if you might know a cross-referencable parts-number for FRONT shocks for it. There are apparently several sources for rear shocks out there. But I haven't been able to find anybody who sells front shocks for the thing. Its current front shocks are completely and totally ruined at this point, being only good for looking at at if you don't mind looking at rust.
Thanks for your help ahead of time, NumberDummy.
Regards, Casey
Old Nov 28, 2012 | 07:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F35CR260617
No parts catalog listing for 1961/66 F350 front or rear shocks. No listing for 1953/60 F350's either. AFAIK, Ford didn't offer shocks for F350's until 1967.
Whatever shocks your truck has, were added by a previous owner from lawd only knows what.
F35 = F350.
C = 292 2V
R = San Jose CA Assembly Plant.
260617 = 1962, assembled February 1962.
Old Nov 28, 2012 | 02:35 PM
desertbus's Avatar
desertbus
Thanks for the reply about the shocks, NumberDummy, and for letting me know about when my old truck's birthday is. My truck was apparently turned into a Class C motorhome right after it was made, and it still retains its original baby-blue oven and its blonde cabinets.
As far as those shocks are concerned, well, I guess I can just completely remove them then, especially since the front beam in it is obviously its original one (six-lug).
Thanks again. These boards are blessed to have you on them.
Regards, Casey
Old Nov 28, 2012 | 04:07 PM
NumberDummy
Shocks were most likely installed by the RV dealer (in Riverside?) who furnished Class C Motorhome body. Does the truck also have front and/or rear sway bars?
If so, another RV dealer add on. There was an RV dealer in Riverside back then that dealers sent their trucks/Econolines to be converted to Class C Motorhomes.
1969: FoMoCo introduced the E300 "Cut-Away." Cargo van that the body was cut off behind the front seats so special bodies could be installed. 1969/74 E300 Cut-Away's were slugs, largest V8 available: 302 2V
E350 Cut-Away introduced in 1975, most thru 1997 came with 460's.
rallymini
Feb 18, 2019 04:36 PM
Supercab
32
Jul 11, 2018 10:31 AM
EXv10
Oct 27, 2012 07:03 PM
edlEBBY
Jun 26, 2012 07:14 AM
ubahd00d
15
Feb 14, 2007 09:16 PM
