Intake manifold question
Old Nov 27, 2012 | 08:34 AM
jeffsang's Avatar
jeffsang
I am preparing to install a factory 4bbl intake on a newly rebuilt 390. I would like to remove the little bypass tube and replace it before installing, so I don't have any suprise leaks. Any tips for removing it and what do I replace it with and what do I seal it with?
Any info would be appreciated
Thanks
Jeff
Old Nov 27, 2012 | 10:28 PM
orich's Avatar
orich
Guess you mean the water bypass, A good fix is by tapping it out and put in a pipe plug.
But don't forget you also must do the same to the water pump too.. I've only seen this done with racing motors that run an open type thermostat so they don't have high water back pressure built up until the thermostat opens. Its there for a good reason. Yes it's a pain in the *** to deal with this why guy go to the lighter Aluminum intakes..orich
Old Nov 28, 2012 | 07:56 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That tube is a press fit, and I believe there are replacements available. I think the one method I've heard about was to put the entire manifold in the oven, heat it up and the tube gets loose enough to pull out. A slide hammer, and a washer thick enough and just big enough to match the inside diameter of the hole, and it should come out. Putting it back, same deal, warm up the manifold, and smack the new one in - carefully
Don't use a torch. Or at least, be careful if you do...
Since it's a press-fit, it shouldn't need sealer.
Old Nov 28, 2012 | 09:02 AM
orich's Avatar
orich
Iron intake about 78 lbs.. Alum 35 lbs Edelbrock say to use s their seal when driving it in. ..
Better find a replacement tube first..
Old Nov 28, 2012 | 11:50 AM
69cj's Avatar
69cj
I've used the ultra black rtv with good results. Normally when you get a new water pump it comes with the pump side tube.
Old Nov 28, 2012 | 05:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Tube, water bypass
C5AZ-8555-A
Steel, straight, 5/8" OD X 2 1/2" Long, cut to length
Perogie Enterprises, Highstown, NJ has 1 (609) 448-5593
Collectors Auto Supply, Oroville, WA may or may not have one, or more. Their inventory control sucks (800) 414-4462
The originals are expanded into the manifold to seal it, it's like the opposite of a compression fit and no additional sealer is needed. I use No 2 Permatex non-hardening sealer when I replace mine.
914fan
Jun 6, 2018 09:13 AM
thebeastof1980
Mar 28, 2008 02:10 PM
deisele75
Nov 16, 2005 07:45 AM
fordguy76
Dec 3, 2004 02:25 AM
lee
Jan 27, 2003 09:00 AM
