4R70W Shifting Problems
Old Nov 26, 2012 | 10:47 PM
Toplait's Avatar
Toplait
Exclamation 4R70W Shifting Problems
Greetings, Folks
2000 f-150 Lariat with 5.4L Triton
VIN: 1FTRX17L2YKA59947
Transmission Type: Door Code: U – Automatic 4R70W
Transmission screwed up today on my fathers truck after running over a curb in a parking lot.... and I'm curious to what could be the possible problem. Any help or advice would be greatly appreciated.
  1. Truck will not go in Reverse.
  2. Truck goes into 2nd gear when placed in 1st, 2nd and also Drive.
  3. When placed in Drive the truck does not have 1st, 3rd, or 4th Gear.
  4. Truck stays in 2nd gear when placed in Drive.
  5. When OD button is pressed, "truck will shift into 3rd gear." When pressed again to try and shift it into fourth gear the truck goes into neutral gear.
The same results happen over and over. The transmission fluid looks new. Truck barely has has over 100k miles and my father babies his truck... So I don't see what possibly could of happened to his transmission. It just started screwing up after running over a concrete curb that separates parking spaces, "by what he says."
Any help would be appreciated.
Thanks for your time.
Old Nov 27, 2012 | 05:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Look under the truck and find what was damaged. I will take a SWAG that the pan was dented, damaging one or more solenoids inside.
Old Nov 28, 2012 | 10:46 PM
Toplait's Avatar
Toplait
Took the truck to transmission shop to have it looked at....Will get back to you with the problem later in future...
12thDad
Nov 4, 2017 04:37 PM
Toplait
Dec 1, 2012 11:16 AM
Toplait
1997 - 2003 F150
Nov 29, 2012 06:56 AM
cmorningstar01
Mar 13, 2009 01:04 PM
CentralMassLandscape
Oct 23, 2008 10:49 AM
