injectors not engaging
Old Nov 26, 2012 | 02:03 PM
brandon2144's Avatar
brandon2144
i have a 1988 f-250 with a 460 motor. i have fuel and i have fire. and the truck starts with i prime it. i tried looking for the crank sensor but can't find it. i looked behind the balancer and i didnt feel any wires or anything. i checked on the sides of the motor nothing. it has a new coil pack and ignition mod. fuel pump and starter. what else can it be?
Old Nov 28, 2012 | 03:33 PM
subford's Avatar
subford
The crank sensor is inside the distributor and called a PIP sensor. The PIP sensor is mounted on the stator assembly.
An 1988 460 does not have a coil pack so I do not know what you changed.
Could be a bad computer but you need to look at some troubleshooting first.
Do the fuel pumps run for one second each time the key is turned on?
Does the fuel pumps run if pin #6 of the test plug is grounded and the key turned on?
If no to the above two questions have you checked the fuel shut-off switch?
If no to the above questions on pump running have you checked the small black wire with a green stripe leaving the NEG post of the battery?
Old Nov 28, 2012 | 03:41 PM
brandon2144
yes it does have a coil pack cause it has the wire from the distrubtor going to it. we think its the fuel relay. cause i was driving down the road and (being a child at heart) i gave it a quick reave before i pulled in the driveway. right after i did that it died. i wire the fuel pump directly to the battery with a toggle switch. but i decided to check to see if its getting fire just to rule it out and when i did it didnt even give me a spark. so now am thinking the coil pack is out or the ignition mod. i was a chevy guy before this truck but i wanted to give ford a chance. and i instantley fell in love with this truck. but this stuff is kinda new to me, especially eletronics
Old Nov 28, 2012 | 04:15 PM
brandon2144
its a ignition coil am sorry dont know if theres a difference
Old Dec 2, 2012 | 11:40 AM
LxMan1's Avatar
LxMan1
Sounds like either the PIP like mentioned above or TFI module.
A coil pack usually has more than one output. You have an ignition coil with a single output. The same thing, but different.
h-m
Feb 25, 2013 03:02 PM
87_f150
Sep 18, 2006 12:45 AM
76fordman
May 26, 2004 06:09 PM
wtodd55
1983 - 2012 Ranger & B-Series
Apr 26, 2004 12:31 PM
bozo4ford
Aug 13, 2003 01:26 PM
