Sponsored by: Real Truck
Fuel filter cap removal.
Old Nov 25, 2012 | 07:28 PM
herbc2004's Avatar
herbc2004
I recently bought a 2004 F-250 with the 6.0 Diesel. The individual who had the truck before me broke the fuel filter cap on top of the motor. This is the cap that takes either a 1/2 ratchet or the socket. Unfortunately they broke off all the ears and I have no way of getting the cap off to replace the filter. I have a new cap already, but can someone please give me some insight on how to get the old cap out??? Thanks.
Old Nov 25, 2012 | 07:49 PM
SC_Hoaty's Avatar
SC_Hoaty
Welcome to FTE!
There is also a 6.0 forum here - so you may want to check with the folks that hang out there to see if they have any suggestions. I have a gasser, so I'm not sure what the component looks like. Can you get a strap wrench or a set of vice grips on it? Are you going to replace it with a part that works when you finally remove it?
Old Nov 25, 2012 | 10:00 PM
galaxie641's Avatar
galaxie641
I'd say strap wrench or really big adjustable pliers.
Old Nov 25, 2012 | 10:25 PM
Yahiko's Avatar
Yahiko
Herbc2004,
Never use the 1/2" drive it will brake the cap. Get a socket that
fits on the cap and only use that. As for how to remove the old one.
Strap wrench really won't grab very well some have tried the adjustable pliers
one other thing to do is get a bit of steel and drill some holes into it place that
over the cap and run 2 #10 screws into the plastic and unscrew it that way
just be ready to replace the filters after your done. Also use a turkey baster
to remove all the diesel int he filter housing so there is not any chunks from the
cap left behind. When you put the new cap on make sure to use some clean motor oil
on the new O-ring and wipe the seal surface on the housing clean each time you change
the filters. Stick with OEM filters and caps for both fuel and oil. The aftermarket ones
will give you nightmares.
Come on over to the 6.0L forum and say hi and feel free to ask any questions.
Here is the link for the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Sean
Motor3440
Mar 25, 2012 04:28 PM
Green_Monster
Nov 9, 2008 10:00 PM
scatgo
Jun 29, 2008 01:56 PM
Sheryle
Apr 15, 2008 09:12 AM
fordf150guy
Jan 19, 2008 07:33 AM
