Broken cap, secondary fuel filter
Ok gents, heres the delema. I did the fuel filter replacement and the primary filter chang and HCFM went with out a hitch. Went to change the secondary filter (engine mount) and had a problem with the cap. The cap on the last filter change must have been put on to tight. I bought a replacement cap at IH ($15.00).
The 15/16ths socket rounded the edges of the nut, and the 1/2 inch drive cracked the side of the plastic nut. There are no leakes from the cap. Any recomendations or experience with removing the cap in this condition.
Tried everything........
Stripped it, broke it with the socket, screwdrivered it, chiseled it.
Now with just really the threaded part in the housing, what would you recommend? It never budged and I am almost sure at 130K someone(Ford) has never seen the inside of this filer housing.
What to do now?
What to do now?
What to do now?
What to do now?
Hope no one GLUED in the threads!
