5.8 misses?
Old Nov 25, 2012 | 06:08 PM
Bigblue351's Avatar
Bigblue351
5.8 misses?
Truck misses or chugs under load. only while accelerating say up a hill. Cant figure it out.
Fuel filter, plugs, wires, cap, rotor, coil all new within last 6-8 months.
ideas? Checked the codes no new codes and no CEL.. Where should i start. its getting annoying!
97 5.8L
Old Nov 25, 2012 | 06:57 PM
bluemtn95ford's Avatar
bluemtn95ford
Could be your tranny and/or torque converter. If your gearing is chewed up. Just my two cents
Old Nov 25, 2012 | 07:28 PM
Bigblue351's Avatar
Bigblue351
Seems unlikey. Still shifts good. Zf5 speed
Old Nov 25, 2012 | 07:44 PM
f-trucker88's Avatar
f-trucker88
check fuel pressure. how many miles are on your truck
Old Nov 25, 2012 | 07:58 PM
Bigblue351's Avatar
Bigblue351
195.000 kms ill check the pressure tomarrow. And it only
Does it 1000-1800ish rpms underload. Like chuggin up a hill
Old Nov 26, 2012 | 05:04 PM
bluemtn95ford
Come to think of it. I had a friend who had the same problem when he was loaded. he said his truck skipped or "chugged". He found that when he was loaded down a wire was being crimped and shorting out. The wire had something to do with the shifting sensor or something. he said he re routed the wire and it solved his problem. not sure if this helps...
Old Nov 26, 2012 | 05:08 PM
bashby's Avatar
bashby
What brand plugs and wires did you use? I've seen LOTS of problems with budget wires.
Old Nov 26, 2012 | 06:38 PM
Bigblue351's Avatar
Bigblue351
The nicer Napa wires and autolite? copper plugs.
elmyers61
Jul 23, 2014 08:59 PM
Red97350
Mar 29, 2010 01:21 PM
MontanaMan
Mar 29, 2007 07:55 PM
raveng60
Bronco II
Feb 22, 2005 08:08 PM
Semperfi45601
1978 - 1996 Big Bronco
17
Oct 4, 2004 12:16 AM
