55 rear sliding window install
Old Nov 23, 2012 | 06:49 PM
DGMFORD's Avatar
DGMFORD
Today I was putting in my front and rear glass, I was thinking the front was going to be hard, but it actually turned out easy. The rear window however (slider from LMC) was not (still don't have it in). LMC says to install the ruber on the truck and install from outside. Midfifty says to install rubber on the glass and install from inside. After tearing my rubber all to crap, I still don't have it in. Any suggestions?
I did get it installed once, but had the rubber on backwards and it would not fit right. The big side of the rubber goes in the inside of the cab right?
The front we put the rubber on the cab and then set the front window, was for the most part easy.
Old Nov 24, 2012 | 06:43 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Do like mid-fifty said, that was how I have installed mine several times. The earlier sliders, like mine, use a thin aluminum flange and I got mine to seal better by putting thin self stick weather stripping on the inside edge of the metal flange prior to putting the window rubber on. Lube it with soapy water and use a pull cord for rolling the rubber inside the cab, just like the front window.
Old Feb 2, 2013 | 09:29 PM
DGMFORD's Avatar
DGMFORD
Okay, so here it’s been a couple months, new seal same problem. I have triedeverything with the exception of cutting the top of the cab off, setting thewindow in and re-welding the cab back up. I have tried the rope; I’ve triedwith WD40, soapy water, a lot of bad words and still can't get that back windowin. It seems like to me that the window is just a pinch too big (top tobottom). When I have the window all the way in at the bottom, the top won'teven make it past the inside of the cab. I'm following the instructions frommid-50's. What I discovered to today is when I have the window pressed into theinside of the cab, the sliders will only open a couple inches each side, it'slike the window is being compressed (too big for the whole). The window was madeby CR Lawrence. Any help here would be much appreciated.
Old Feb 3, 2013 | 12:40 AM
Project-55's Avatar
Project-55
Cut some cardboard strips (maybe 2 x 3) and test fit your window frame buy resting it on several strips at the bottom and you should still be able to slip them in on top and the sides. The frame should have a little less than an 1/8 inch gap all the way around.
You may have to trim the frame slightly.
Old Feb 3, 2013 | 08:04 AM
3golfjack's Avatar
3golfjack
Try this link.
Mid Fifty F-100 Parts - Instructions - INST-3103_REAR_RUBBER_INSTRUCTIONS.pdf
Old Feb 3, 2013 | 03:06 PM
DGMFORD's Avatar
DGMFORD
thanks for the info, I'm going to order new W/S from mid-50's and try again. Will also check to make sure I have enough clearence between the slider frame and the cab. Wish me luck.
ericford1984
Jan 21, 2012 04:07 PM
Mustang65432
Aug 18, 2010 10:20 AM
jaye
Sep 30, 2009 12:26 AM
flareside_thunder
Apr 28, 2007 04:52 PM
bart6180
Oct 18, 2006 05:42 PM
