Replace rear window!?
Old Jan 20, 2012 | 04:46 PM
ericford1984's Avatar
ericford1984
I have a sliding window that was originally installed but removed tofix rust around cab window. I ordered a new seal from lmc. But confused on what way it faces an how toget it in the window it's self
Old Jan 20, 2012 | 05:27 PM
Franklin2's Avatar
Franklin2
Can't help you on how it faces, but you use rope and something slick on the rubber to install the window. The rope goes into outside groove of the rubber after the rubber is installed around the window. While you are putting pressure on the window in the cab opening, someone inside pulls the rope out of the groove and that makes the rubber jump over into the cab and seats it into the cab opening.
Old Jan 20, 2012 | 06:13 PM
Anafiel's Avatar
Anafiel
Wow, anyone have a video of that? I just can't wrap my mind's eye around that description...
Old Jan 20, 2012 | 06:20 PM
nikmish's Avatar
nikmish
1967 Chevy Pickup Back Window install - YouTube
Old Jan 20, 2012 | 06:52 PM
81ChopTop's Avatar
81ChopTop
^ I've never seen it done like that before. Learn something new every day. I've always used a couple of screwdrivers and had pretty good luck that way.
Old Jan 20, 2012 | 07:02 PM
Franklin2's Avatar
Franklin2
Screwdrivers can chip the glass and scratch the paint if you are not careful. They are pretty much what you have to use to get the old glass out if you want to save the old rubber though.
Old Jan 20, 2012 | 07:48 PM
Anafiel's Avatar
Anafiel
Great video. Thanks!
Old Jan 21, 2012 | 01:12 AM
xirxious's Avatar
xirxious
Do they make replacement seal kits for them? My 1986 F250 slider and rubber is coming apart.
Old Jan 21, 2012 | 07:02 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can get a rubber window seal from LMC.
Or are you talking about the fleece channel the glass slides in?
If you want a window gasket you need to know if it has the push in moulding and if it is a factory slider.
Factory sliders have a double wide channel in the rubber, aftermarket sliders have a thinner flange that will fit a fixed glass gasket.
Old Jan 21, 2012 | 04:07 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Rear Window weatherstrips that fit our trucks with Factory installed Glass...
D3TZ-1042084-A: For Factory Brushed Aluminum Sliding Rear window: 1973-1981
E0TZ-1042084-A: For Solid Window, without insert moulding: 1980-1996/7
E0TZ-1042084-B: For Solid Window, With insert moulding: D7TZ-1042430-A: 1980-1996/7
E2TZ-1042084-A: For Factory Sliding Rear Window: Requires insert moulding: D7TZ-1042430-A: 1982-1996-97
You can tell if the window is factory or not because Ford glass is etched with CARLITE on it or with replacement glass the Ford Oval Logo.
Notice it says to use sealer in the top corners around the Roof and cab "B" pillar seams.
salf100
Jan 18, 2010 05:37 PM
flareside_thunder
Apr 28, 2007 04:52 PM
bart6180
Oct 18, 2006 05:42 PM
jor
Paint & Bodywork
May 24, 2004 10:20 AM
supercab78
Jul 30, 2003 10:00 AM
