Dashboss
Old Nov 23, 2012 | 04:49 PM
Spoon_I's Avatar
Spoon_I
Dashboss
Just purchased a Dashboss for my 2004 F250. Anyone else use one of these? If so, what parameters are you monitoring?
thanks
Old Nov 23, 2012 | 06:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
There are a few of us here...
Here are some screen shots:
Josh
Old Nov 23, 2012 | 07:32 PM
Spoon_I's Avatar
Spoon_I
Do you have the EGT add on?
Old Nov 23, 2012 | 07:36 PM
Bullitt390's Avatar
Bullitt390
I don't. Maybe someday. I don't intend on towing anything of significance for awhile so it isn't a priority to me.
It's easy to do. FTE member Lilpooh has a write-up over at dashBoss.
"How to" add A/D external ports.
Josh
Old Nov 24, 2012 | 05:45 AM
Lilpooh's Avatar
Lilpooh
Get the EGT kit from the DashBoss website, it's much easier to hook up than the first one I used.
Old Nov 24, 2012 | 08:31 AM
wdglide's Avatar
wdglide
I'm thinking about picking this up too. So its just the main unit and the single channel EGT kit that's needed?
Old Nov 24, 2012 | 08:57 AM
Lilpooh's Avatar
Lilpooh
The main unit (DashBoss gateway OBDII) is a good starter, if you want to add EGT then get the EGT single channel kit, then for another $30 you can add Fuel psi.
The link that Josh provided also shows adding Fuel psi sensor and set-up. Here is where I got the sensor, but any 5v sensor will work. If you go with a different 5v pressure sensor, you will need to find out what the volt to psi settings are.
http://item.mobileweb.ebay.com/viewitem?itemId=250799543734
Old Nov 24, 2012 | 09:24 AM
Spoon_I's Avatar
Spoon_I
Good Stuff
Lilpooh, thanks for the info. Your post over on the DashBoss forum was the deciding factor for me purchasing the DashBoss vice the SQII. Do you mind sharing what alerts you have set up on your DashBoss?
Old Nov 24, 2012 | 09:26 AM
wdglide's Avatar
wdglide
Just ordered it myself!
Old Nov 24, 2012 | 11:32 AM
Lilpooh's Avatar
Lilpooh
Unfortunately as Josh has found out, being a beta tester has its drawbacks. Every time we get a update (sometimes 4+ a day), the DashBoss resets to factory defaults. So I don't bother setting up my alerts, it just keep an eye on my readings.
For those who set-up parameters with alerts, I recommend you read this.
https://www.ford-trucks.com/forums/9...-pressure.html
Old Nov 24, 2012 | 02:15 PM
Bullitt390's Avatar
Bullitt390
The only parameters I have alarms set is FICM main power and Battery.
Josh
Old Nov 25, 2012 | 01:04 PM
villestrip's Avatar
villestrip
Do you guys hav any pics of the ahboss mounted in your truck? And o you keep it plugged in all the time to keep the iphone charged?
Old Nov 25, 2012 | 01:14 PM
Bullitt390's Avatar
Bullitt390
I use the dash mat that comes in the kit. Works pretty well.
I don't always have Dashboss running, if it's a short drive I leave the phone, longer drives I use the cigarette charger.
Josh
Old Nov 25, 2012 | 01:25 PM
Lilpooh's Avatar
Lilpooh
The mounting possibilities are endless. You can go with a store bought suction cup, solid mount, or with a little imagination make your own custom mount.
I made my own from Lexan (plexiglas), cut the shape I wanted and used a heat gun to make the bends needed, then used industrial Velcro to mount to dash.
As for battery life, I run the 4s. Full charge and left for Canada fish trip, an 8hr drive. With about 5 apps running in background, push notification on. After 8hr drive, battery went from 100% to 43%.
Old Nov 25, 2012 | 02:08 PM
acf6's Avatar
acf6
Thats pretty neat... i would take a dremel or similar and cut out a little slot for the charger for extended trips
