Dashboss
Old Nov 25, 2012 | 03:02 PM
Lilpooh's Avatar
Lilpooh
Originally Posted by acf6
Thats pretty neat... i would take a dremel or similar and cut out a little slot for the charger for extended trips
LOL!! 8 hour drive is long enough for me!!! When I use the charger with that mount, the phone sits at an angle, which is no big deal.
I have thought about spray paint the outside with tint for lens or spray with the Krylon Fusion matched paint for plastic.
Old Nov 25, 2012 | 03:06 PM
acf6's Avatar
acf6
true... i have an aftermarket head unit with a USB input on the front though, so i use my phone for music/charging
Old Nov 25, 2012 | 03:25 PM
Lilpooh's Avatar
Lilpooh
Perfect! If your head unit has composite RCA jacks, then you use DashBoss video out to display the gauge readings on your head unit.
Dashboss video out - YouTube
Old Nov 25, 2012 | 04:26 PM
wdglide's Avatar
wdglide
I just checked out that video. Does the RCA cable connect to the Dashboss unit or the iPhone?
Old Nov 25, 2012 | 04:36 PM
Lilpooh's Avatar
Lilpooh
Cable goes from the iPhone to the head unit. The Apple composite cable is for RCA jacks. If your head unit has a VGA input, then you could use the iphone4 and 4s with the iPad VGA cable.
Old Nov 28, 2012 | 11:15 PM
Spoon_I's Avatar
Spoon_I
Just got my Dashboss in the mail today. It came with the EGT kit. Waiting on the fuel flow sensor now......
Old Nov 28, 2012 | 11:19 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Welcome to the brotherhood.
Josh
Old Nov 29, 2012 | 08:37 AM
wdglide's Avatar
wdglide
Received the EGT. Just waiting on the Dashboss and fuel sensor!
Old Nov 29, 2012 | 02:30 PM
Canadianpowerstroke's Avatar
Canadianpowerstroke
well been playing with my dash boss and i love it, i clear the DTC's and one of them is the only one that comes back is the P0069
manifold absolute pressure corrulation.
after the engine light comes on i clear it and about 100 kms later it comes back on.. im stumped.
Old Nov 29, 2012 | 03:44 PM
Bullitt390's Avatar
Bullitt390
Did you check the rubber line to the sensor or the wiring?
Josh
Old Nov 29, 2012 | 05:54 PM
Canadianpowerstroke
Josh I wish I knew what the rubber tune was
Old Nov 29, 2012 | 06:17 PM
Bullitt390's Avatar
Bullitt390
?????????? The MAP sensor has a vacuum line that runs from the intake manifold to the sensor. Also has an electrical connector.
Sounds like either the connector or vacuum line is compromised to throw you CEL
Josh
Old Nov 29, 2012 | 06:24 PM
  #28
Lilpooh's Avatar
Lilpooh
Picture time!! In the first pic my hose is RED, your will probably be BLACK, this hose goes from the intake manifoild fitting to the MAP sensor. The second pic I'm pointing at the bracket for the MAP sensor, behind bracket you will find the MAP sensor. The hose or the fitting in the intake may be clogged with soot.
Old Nov 30, 2012 | 06:07 PM
  #29
Canadianpowerstroke
ok Pooh the hose is there.
Old Nov 30, 2012 | 06:14 PM
  #30
Bullitt390's Avatar
Bullitt390
pooh that hose if its not there would that throw the code.
Not Pooh, but you need that hose connected
Josh
