transmissiong fluid refill?
Old Nov 22, 2012 | 12:26 AM
dyoungen's Avatar
dyoungen
We're in the process of putting a straight 6 300 in my sons truck. After everything that happened most of the fluid leaked out all over the floor. About how much oil does it take in the C4?
Old Nov 22, 2012 | 12:34 AM
Evan's F250's Avatar
Evan's F250
If you're going to change it, drain the torque converter also. Take the inspection cover off, have someone bump the starter (if possible) until u see the drain plug it should be 7/16. I just changed mine in my c6..converter & all. it took 12.5 qts. With a c4 my guess would be 10-10.5 qts. Put in 8 and keep checking dipstick.
Old Nov 22, 2012 | 07:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4 = 11 quarts including the torque converter. Make sure you use the same ATF. 1964/76 C4's used Type F / 1977/84's used Mercon.
bohiaa
15
Oct 6, 2017 06:46 PM
dyoungen
Dec 23, 2012 05:45 PM
artfuldodger
Nov 8, 2006 07:27 PM
Borgunit
17
Sep 7, 2004 09:02 AM
jlillie
1997 - 2003 F150
May 30, 2003 10:27 PM
