Automatic Trans. Fluid change problem
Old Nov 3, 2006 | 08:44 PM
artfuldodger's Avatar
artfuldodger
Arrow Automatic Trans. Fluid change problem
I have a 01 EB Expy and wanted to change AT fluid myself so I got out the manual from Ford and the Haynes manual to find capacities and fluid type which turned out to be 15.5 litres (16qts.) of Mercon. I dropped the pan, after draining the tranny, replaced the filter and gasket, replaced the pan, and put in 15 litres of ATF. There was loads of ATF running onto the floor so I drained (after several fluid reductions about 8 litres of ATF until finally I arrived at the hot-full line while the motor was running. It turned out that I had only initially drained about 7 litres of ATF. Why is the capacity of the 4R100 tranny given as 15.5l. when it holds only about 7 l.?
On another topic the Ford manual says not to change the rear differential gear oil ever, unless work has been done on the axle,differential, or the axle has been submerged in water. Okay, fine, but what about the front differential?
Thanks in advance for your answers. Artful Dodger
Old Nov 3, 2006 | 09:38 PM
Franklin2's Avatar
Franklin2
The capacites you found are for a complete teardown when the tranny is dry. A filter change usually only requires 3 or 4 quarts, depending on the tranny. 7 seems a little bit much, so after you get it hot running down the road, check it again. It may have too much in it still(I don't know this, I am not familiar with your particular tranny).
Most of the oil is in the torque convertor. On most vehicles, the torque convertor can't be drained, though Ford did make some were you could. On my 1980, I can take the flywheel covers off, bump the starter around, and take a drain plug out of the torque convertor. I can drain all the oil this way. I think mine(c6) takes about 14 quarts when I drain the convertor.
Old Nov 3, 2006 | 11:06 PM
Genes04Expy's Avatar
Genes04Expy
to much fluid
The reason you had to much fluid is you did not drain the torque converter which holds more than half of the fluid. What you did is called basically a tranny service. Change the filter and the fluid you get out of the pan and that is what you need to put back. Not sure if your torque converter has a drain plug on it. If it does you can drain it To get all the fluid is best done with a trans fluid exchange machine done by a repair shop.
Old Nov 6, 2006 | 08:47 PM
Jimmygunz3's Avatar
Jimmygunz3
The torque converter has most of the fluid, if you have the 4r100 then you should have a drain on the torque converter, look at the tranny and you should see a black rubber cap, that is where the drain plug is. I am actualy going to change my fluid and filter this week.
Old Nov 6, 2006 | 09:05 PM
Ibarria's Avatar
Ibarria
what about the 4r70w?
Old Nov 6, 2006 | 11:01 PM
BigMike_951's Avatar
BigMike_951
When you have the tranny flush it replaces ALL the fluid, correct?
Old Nov 7, 2006 | 06:55 AM
projectSHO89's Avatar
projectSHO89
Almost all of it. Impossible to get ALL of it.
Steve
Old Nov 7, 2006 | 12:52 PM
Gevans17's Avatar
Gevans17
4R70W transmission
My 1998 4R70W transmission has a plug to drain torque converter.
Old Nov 8, 2006 | 04:04 PM
aagitch's Avatar
aagitch
I would recommend changing the rear differential fluid and front. Many people here have regardless if it got submerged or worked on.
Old Nov 8, 2006 | 06:57 PM
ga4kicks's Avatar
ga4kicks
I find that dropping my transmission pan, replacing the filter, cleaning the magnet, and replacing the fluid is good maintenance on the transmission. I don't really care about replacing all the fluid at once.
Old Nov 8, 2006 | 07:27 PM
Cecil Little's Avatar
Cecil Little
Smile Fluid Change problem
When I changed the Tranny fluid I also drain the converter. When I add the new fluid I only put in about 6 qts then I start the engine so that the fluid goes back into the converter then shut it off and add another 6 qts and repeat procedure. I usually end up adding around 14-15 qts total. I have a E40D Tranny in my 97 Expie 4X4 with 213K miles.
Ford777
Sep 26, 2016 04:11 PM
efair
24
Oct 7, 2014 04:35 PM
cavon76
Aerostar
Aug 6, 2006 12:13 PM
quick35th
Nov 25, 2005 07:49 PM
Paarrothead
Oil & Lubrication
22
May 30, 2002 08:03 PM
