location on electrical components
Old Nov 21, 2012 | 12:49 PM
Emyl's Avatar
Emyl
Hi.. I am curious about where I might find the multi function switch for the turn signals and stop lights?
Also where on the frame is the taillights grounded?
1991 F350 7,3 crew 4x4
Old Nov 21, 2012 | 01:01 PM
Volvo92906's Avatar
Volvo92906
Multifunction switch is in the steering wheel, right where your turn signal handle goes in.
Old Nov 21, 2012 | 01:06 PM
Emyl's Avatar
Emyl
according to the wiring diagrams I've seen the cables from the break pedal should also run through there?
I'm a bit confused by this.. there was a service bed installed earlier.. amd I'm guessing the tail/turn/stop lighs did not look the same.. now I have a long bed from a 1994 F250 and cant really get the stop lights to function correctly
Old Nov 21, 2012 | 09:37 PM
Phy's Avatar
Phy
The brake light circuit has to go through the multifunction switch so that when you're on the brakes the turn signals still work.
BluZ
Jan 7, 2015 03:41 AM
Fastback460
Mar 22, 2013 02:06 PM
feeniks4.9
Feb 12, 2008 11:01 PM
P-47
Apr 19, 2006 10:04 AM
GSchretter
Mar 31, 2003 12:38 AM
