Looking for Advice - 06 6.0L
I have been reading some of the great tech information at the top of the forum, but much of the reading has given me more questions. I have an 06 6.0L 350 that has just recently started to have a few issues, and I was hoping for some advice on how to move forward.
As of lately, when I go to fire up the truck, the starter turns much "longer" than it used to before firing, and when it does fire, the RPMs jump up, fall and jump again before settling to the normal running RPM. I swear I can smell fuel through my vents and the gas mileage is showing less than 10mpg (used to be 14-15). But I see no visible fuel leaks. I am confident that it's a fuel issue, probably injectors. Once running the truck runs just like normal, no skips, no lack of power, just normal.
I have an extended power-train warranty and was thinking of taking it to the dealership, but honestly I've been down this road with other vehicles and dealers are not always the best solution. I read in the tech forum about making sure the "software" is up to date on these models - is the dealer the guys who have that software? I am debating taking it in or going to a couple of good local diesel mechanics around my area.
I appreciate any advice on what to do, and my apologies if I didn't search enough before posting. My hours at work don't allow me to comb the internet for solutions, and most of this tech is over my head anyhow.
There are options for testing and software updates from private shops but if the warranty is from Ford I would recommend a dealership. It relatively common for the fuel pressure regulator to leak. There is an updated spring available (and recommended by Ford/International) that will raise the fuel pressure a bit and provide some additional cushioning to the internal parts of the injectors. You may be correct about the injectors being the issue if they have operated for an extended time with low pressure. The kit comes with new seals that will address the leak issue.
The latest software is the only thing available from the dealer and it has proven to be a mixed bag of results. Many reports here (and other sites) of lower fuel mileage and reduced power.
I would suggest local dealer install "blue spring" fuel pressure regulator update, inspect for other possible fuel leaks, perform injector diagnostics, and NOT update the software.
Welcome to FTE!
pop
BUT, I ended up putting in back in the shop yesterday. I live in NC, and the mornings are beginning to get colder, but I would not say FREEZING or anything beyond normal winter-ish weather. The truck took almost 10 seconds of turning over before it fired.
NEW QUESTION: In the colder mornings, when I fire up the truck, it runs like Pure-T-Dog-*****. It sounds like parts are banging around everywhere inside, or like no oil is going into the head and parts are slamming each other. Once it warms up for about 10 minutes, it's fine. Drives fine - no worries at all. Even my dad was like WTF when he heard it. This is only an 06 model. For you guys around that age, is this normal? Should it run so rough when you fire it up? I wish I could give you audio on it.
Testing the FICM
My choice if repairs are needed.
If you have a cold weather plug, plug it in for about 3hrs then see how it runs at start up.
pop
Davbeisner - you are correct as well. I spoke with the service tech this morning who said I have 3 bad injectors. They are working on providing the fix under warranty.
However, my first question when I ride back up there will be, as nicley as possible, "why the hell wasnt this found last week????". My own common sense would tell me, if there is low fuel pressure to start with, check and ensure the system is operation, which would include injectors in my opinion. Maybe I'm wrong - I can't say I'm disappointed - I've always avoided having the dealerships work on them for a reason..
Thanks again for your help guys. I'll post a quick rundown of what they fixed/replaced on my truck - maybe it will help some of you in the future who may have the same issues.
Trip 1 to dealership (Not Covered Under Powertrain Warranty): They replaced the fuel/water separator sensor which had gone bad. The fuel smell I had was due to a a bad o-ring for the fuel filter at the fuel/water separator. The "Water in Fuel" light doesnt keep coming on and the fuel smell is now gone. +/- $ 530 bucks.
The 2nd trip to the dealership was because they didnt keep the truck long enough to do a true cold start. Once they did, they found a few more issues, which as as follows:
Trip 2 to dealership (100% COVERED UNDER POWERTRAIN WARRANTY): They replaced the valve cover gaskets. They also replaced dummy plugs and injectors 2, 4 and 8. They tested air in the line and ended up putting on a STC replacement kit. +/- $ 2,300 bucks covered under warranty.
To date, the truck starts great in the colder mornings, and runs better in general. The gas mileage has increased to where it was prior to having the issues. I never thought I'd say this, but I'm happy with the dealerships work and customer service throughout the process. I'm very surprised it was something actually covered under warranty and not the typical "Welllll, the warranty doesnt cover this part" story.
I have come out on the better end of the deal here - the warranty was originally around $ 1,500 bucks so I feel I've got my money out of it.
and start monitoring your engine... there is a tech folder up there ^^^
with a ton of information.
this is very important.
coolant, alternator and battery voltage, and oil changes are the
three big sinkholes on this engine. if not maintained correctly,
they can cause cascading problems above the $5k repair bill level.
