6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 help needed
Old Nov 20, 2012 | 09:25 AM
a4t1rat's Avatar
a4t1rat
6.4 help needed
I have a 2008 f450 it has been dpf deleted and egr deleted. Its running a H&S xrt pro. it has had intermittent starting problems. and now has developed stalling problems. It has beed to the dealer 3 times and the have said there is nothing wrong. It has no codes and runs perfect after you get it started. I live in Utah at 5000 ft. today I went to start it and it wouldnt start but after about 10 tries it started, tried to drive it made it about 1/2 mile and it quit and didnt want to start. finly got it running and quit again.. still no codes ?? when it quits it is like you just shut of the key. And when you try to start it it will turn over but no fire, any ideas would be helpful as I am about to ... well never mind. I dont think it is PATS problem that has been fixed. On a side not I now the truck has a new motor so maybe loose connection? truck has 90k on it now
Old Nov 20, 2012 | 08:53 PM
StanleyZ's Avatar
StanleyZ
Sounds like some sort of computer glitch. Have you tried taking the tuner back to stock and reloading, or disconnect both batteries and see if that will reset something. I guess batteries are good, since it sounds like they do a lot of cranking. Sometimes a bad battery can cause a lot of very strange things to happen in electrical system. It's got to be something vey unusual if there are no codes and the tuner is something the ECM would not recognize so that would be my number one suspect. But, I'm pretty much an amature. Good luck, let us know what you learn.
Old Nov 21, 2012 | 09:07 AM
a4t1rat's Avatar
a4t1rat
I have disconnected the battries, I belive that they are good I guess I could test them for sure but they seem to be in great shape.. they are optima and fairly new? I have actually tried a new tuner I now have 2 a mini maxx and a xrt pro. I know it has to be something wierd so any thoughts are help. Another funny thing is it was acting up a little here in Utah then I drove it to California stayed a week and it ran perfect.. came back to Utah and it started acting up again .... I guess its just a california girl .
Old Nov 21, 2012 | 01:14 PM
galaxie641's Avatar
galaxie641
Isn't there something about a rubbing wire harness on the 6.4L that can cause this? Want to say TSB or even a recall.
Old Nov 21, 2012 | 06:00 PM
StanleyZ's Avatar
StanleyZ
So it ran great in CA but not UT. It probably doesn't get state lines but could it be " ran good in flat lands runs bad at altitude"? There's some stuff that altitude changes in the fuel system but I can't say what. Change your thread title to something like "bet you can't figure this out" and some of the real wrench heads will be jumping all over this riddle. Where are you Sennix? Cheesit?
Old Nov 21, 2012 | 06:04 PM
RM2738's Avatar
RM2738
Did you happen to try and clean your engine bay recently? A buddy of mine had similar issues immediately after spraying down his engine at one of those pressure washer places with the "engine degreaser."
Old Nov 21, 2012 | 06:42 PM
senix's Avatar
senix
Start simple. Fuel filters. Have you changed them recently? Check them. Especially the one on the engine. Pull it and check the fuel bowl. If nice and clean and the filters are less then 10K put them back in.
When you turn the key to the on position do you hear a buzz for the low pressure fuel pump? Does it pressurize and then turn off?
Old Nov 22, 2012 | 05:47 AM
senix's Avatar
senix
Another thought comes to mind. SBJ or smart junction box. Check all the connections there.
Also the wiring harness in the engine bay beside the airbox. Check to make sure it is not loose or one of the pins is dirty, bent or pushed in.
Old Nov 22, 2012 | 09:19 AM
vloney's Avatar
vloney
A pcm will store codes if it "sees" a problem. Lose power or ground for the PCM it wont "see" anything, because its dead. Start there.
Old Nov 26, 2012 | 07:20 AM
a4t1rat's Avatar
a4t1rat
Well I changed the filters just because I wanted to eliminate it and after getting the air out it is back to the same thing. worked all day getting the air out and had it running good next morning wont start again... left it sit and went to try and start it a few hours later and it started right up ?? it will turn over no fire??
what about a sensor somewhere ?? Any help is great. Thanks
Old Nov 26, 2012 | 09:19 AM
a4t1rat's Avatar
a4t1rat
I was thinking the Lift pump as a possibility... I do hear it run for sure sometimes other time I cant tell with the stupid dinger going off... it there a relay, iam sure there must be I will check that and try to listen for the pump. I have been thinking it is a fuel issue
Old Nov 26, 2012 | 01:35 PM
a4t1rat's Avatar
a4t1rat
I forgot to add that the truck only does this in the morning.. if it starts it will run flawless the rest of the day. Also is cold related ... and if I plug the truck in it will still do it. I belive it ran great in California due to the warmer temps??
MikeT2351
6.7L Power Stroke Diesel
Feb 7, 2019 06:36 AM
PEG
1997 - 2003 F150
Nov 5, 2014 08:11 PM
dmanshane
33
Dec 26, 2011 07:12 PM
Mihylo33
Jan 13, 2011 09:25 PM
wormslinger
Apr 2, 2005 07:58 PM
