Wtf spitting coolant everywhere?!?
Old Nov 19, 2012 | 10:51 AM
Greg5OH's Avatar
Greg5OH
Rebuilt oil cooler 2 weeks ago. burped cooling system. Now randomly ill have coolant spraying from i dont even no where, it was getting past some hose clamps , tighted the **** out of em, was fine for 200 kms. do a small in town trip next day,look under hood coolant spray by thermostat housing, looks to he spraying front under hose clamp.
Guys im stumped om this. Everything was fine with regards to cooling before i rebuilt the cooler.
Old Nov 19, 2012 | 11:37 AM
whiteboyslo's Avatar
whiteboyslo
Pinhole leak in hose?
Mike
Old Nov 19, 2012 | 12:38 PM
Greg5OH's Avatar
Greg5OH
naw, its from random areas all iver. i di havethe coolant level in the rad quite high..wondering if that was causing the cap not to open?
Old Nov 19, 2012 | 04:01 PM
joshofalltrades's Avatar
joshofalltrades
it seems i recently read a thread here about someone using a champion radiator cap that wouldn't open at the specified pressure and was causing similar problems. a new cap would be my first step, borrow it from something else if you need to for a test.
as you probably know, the radiator should be filled full when cold, and the overflow bottle should have just a little in there. as it warms up, the cap should open at the specified pressure and send some of the fluid to the overflow bottle, and should pull that fluid back once the engine cools off.
Old Nov 19, 2012 | 04:08 PM
Greg5OH's Avatar
Greg5OH
bought a mew cap, exact same as old ome both take same amount of force to open it. i took some coolant out (it was all the way up the neck) seems to be ok now..ill take it for a spin tonight see if it spits
Old Nov 19, 2012 | 04:10 PM
whiteboyslo
Does 'all over' include inside the shroud? Coolant leaking from around the upper hose where it attaches to the radiator will drip into the fan, and the fan will sling it EVERYWHERE. So, if the inside of your fan shroud looks wet, check your upper rad hose at the rad end.
Mike
Old Nov 19, 2012 | 06:59 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
get a coolant system pressure test kit and pump the system up and see where it leaks from. you can also get some dye and UV light to check for leaks.
Old Nov 19, 2012 | 08:10 PM
tecgod13's Avatar
tecgod13
Radiator, and the entire cooling system, should be filled to the top, NO AIR. When the engine warms up, the coolant will expand and push out into the overflow tank. When it cools back down, it will coolant shrinks back to initial size, and anything that ended up in the overflow will end up back in the radiator.
Which also means the overflow tank should be about half full, so in case there are small leaks, the radiator stays topped off.
I would check all the hoses and connections. If the hoses are that old, just replace them as they don't last forever, and are pretty cheap. The pressure test sounds like a good idea. The fan will blow coolant (or any leak) all over the place making it hard to find the actual leak.
Noveske
Apr 1, 2010 08:34 PM
MMSGuthrie110
Feb 6, 2010 10:23 AM
Robbgt
Dec 8, 2006 12:20 PM
EK082
Oct 1, 2003 08:12 PM
ASH
Aug 6, 2003 07:41 AM
