Coolant/hose
Old Feb 5, 2010 | 10:41 AM
MMSGuthrie110's Avatar
MMSGuthrie110
Coolant/hose
okay so I drove to school today. parked there for like 2 hours. when i came back out i popped the hood to show someone something. i noticed the upper and lower rad hoses were both sucked completely shut. i just flushed and filled coolant like a month ago. when i took the cap off it looked like brown mud at the top. When i ran it for a minute they looked fine. It was low on coolant i probably added like 2 quarts. I just replaced the hoses an hour ago and haven't noticed it do it yet. just wondering what was cause it other than old hoses.
Old Feb 5, 2010 | 10:52 AM
MMSGuthrie110
***btw i think the muddiness i mentioned might have been because i put in a bottle of rad. stop leak when i flushed it
Old Feb 5, 2010 | 12:20 PM
lew52's Avatar
lew52
Pressure test the cooling system , check the thermostate , if no leaks flush again & add coolant ...Lew
Old Feb 5, 2010 | 12:25 PM
lew52's Avatar
lew52
Check the rad cap to ..
Old Feb 5, 2010 | 12:41 PM
quicklook2's Avatar
quicklook2
don't use stop leak.
causes more problems then it solves.
thermostat could now be clogged.
Old Feb 5, 2010 | 05:38 PM
MMSGuthrie110
I think the thermostat is okay. tempature sits right in the middle like it always has
Old Feb 5, 2010 | 05:51 PM
lew52's Avatar
lew52
Well then check the other stuff , you must of had a leak ?? you put stop leak in it ?? ..Lew
Old Feb 5, 2010 | 05:55 PM
skyfox10's Avatar
skyfox10
This stuff makes your coolant look brown muddy????
AHHHHHH!!!! that's how my coolant looked when I bought the truck! I hope they didn't put that stuff in there.
Old Feb 5, 2010 | 08:11 PM
fordman1090's Avatar
fordman1090
the brown is rust and crap from the radiator and such. Its broke free when you flushed it, and is now floating about, its normal for these truck.
I'd bet the cap is bad and causing the system to build a vac.
Good Luck
Old Feb 6, 2010 | 09:18 AM
EPNCSU2006's Avatar
EPNCSU2006
I also believe the cap is the problem...
Old Feb 6, 2010 | 10:23 AM
RustyGreen's Avatar
RustyGreen
I agree with the rad cap. Also, it's a pretty cheep part to throw at it to eliminate it as the cause before you go do more major things.
ElMoco
46
Nov 28, 2016 09:42 PM
flyinghi3
Apr 23, 2013 01:56 PM
geoaigel
Jan 4, 2009 10:53 PM
azchris
Feb 14, 2008 03:09 PM
upstream
Modular V8 (4.6L, 5.4L)
Oct 19, 2007 02:43 AM
