6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
AC Vent Removal
Old Nov 18, 2012 | 07:00 PM
RM2738's Avatar
RM2738
AC Vent Removal
AC Removal. Sorry for the typo. Anyone know how to remove/replace one of the AC Vents? Somehow the little plastic clip broke on the one to the immediate right of the head unit. The two air deflectors no longer move simultaneously and it annoys me.
Old Nov 19, 2012 | 08:04 PM
pdiesel's Avatar
pdiesel
Air Vent Replacement
Yes, It is pretty simple. You must remove the center dashboard panel surrounding the stereo and air controls. If you google 2008 f250 radio removal, you can print downloadable instructions. The center dashboard panel contains the vents. Once you remove the dash panel, flip it over to view the vents from the back and you will see clips that hold the vent into the dash panel. The vents have clips on the back that you can pry loose(from the backside),and the entire vent can then be removed from the center panel. I bought used vents from Ebay for 1/3 the cost from the dealer. The replacement vent simply snaps back into the center dash panel. I had two vents break just as yours did. Good Luck!
jonrjen
6.7L Power Stroke Diesel
Jul 12, 2015 07:43 AM
Rusty_S
19
Jun 14, 2014 06:56 PM
smallello
May 28, 2012 07:06 AM
blgrable
Aug 29, 2004 01:12 PM
tulkas
Aug 4, 2004 06:13 AM
