Sponsored by: Real Truck
Manual hub question
Old Nov 17, 2012 | 03:19 PM
abranz's Avatar
abranz
Manual hub question
If I convert the ESOf on my 2002 do I need to replace the vacuum axle seals skf 28600? I ask because they are expensive and don't want to replace them if all they did was seal the hub for vacuum. Of coarse I don't want dirt/ water on the hub either. Just not sure which seal does what. Thanks Anthony
Old Nov 18, 2012 | 11:45 AM
bakon's Avatar
bakon
They are for vacuum for sure. Mine were worn and drove it over year without using electronic lock.Once replaced they worked fine,and nothing else was damaged or needed replaced. Dont know if they protect anything else, but didnt hurt anything either.
Old Nov 18, 2012 | 08:04 PM
abranz's Avatar
abranz
Thanks. I tore it apart today using this sites info and realize The seal is necessary.
Old Nov 18, 2012 | 09:39 PM
Firefighter 1406's Avatar
Firefighter 1406
I was thinking so. Couldn't get your part number to pull up to take a look. Glad you got it all figured out.
mmenzies
Feb 20, 2017 04:17 AM
Watcher58
Aug 30, 2015 01:46 PM
WatsonR
Sep 8, 2014 08:22 PM
lariatbob
Feb 5, 2008 09:14 PM
djsimonds
Dec 22, 2005 10:29 AM
