Sponsored by: Real Truck
Replacing hub assm.
Old Dec 21, 2005 | 03:47 PM
djsimonds's Avatar
djsimonds
Replacing hub assm.
I have a 01 F-250SD 4x4, need to replace the left front hub assm. Any special tools I need besides snap ring pliers?
Thanks
Old Dec 21, 2005 | 04:31 PM
DCSpecial's Avatar
DCSpecial
Can't think of any special tools......just some sockets, rachet, torque wrench, a breaker bar, needle nose pliers, possibly a deadblow hammer or some sort of hammer, and some pentrating oil are all I can think of.
Old Dec 22, 2005 | 05:53 AM
kenneBF250V10's Avatar
kenneBF250V10
Also, make sure you replace the thin yellow o-ring that fits onto the hub itself. This is a vacuum seal and if it is damaged you will have issues with your 4x4 engaging since the hubs are vacuum operated. Inspect the large and small axle seals as well. The large seal (close to the universal joint) will need to be pressed on. The smaller seal can be pressed on by hand and is the one that seals off the axle tube itself. When it goes bad it usually separates and breaks into two pieces. If your truck has a lot of miles on it, you might be better off just changing those seals to be on the safe side. Other than that, all you need is a little time and patience.
Old Dec 22, 2005 | 09:55 AM
Racerguy's Avatar
Racerguy
For some more hints take a look at https://www.ford-trucks.com/forums/s...ht=ball+joints
Old Dec 22, 2005 | 10:29 AM
Fat Diesel's Avatar
Fat Diesel
Do yourself a favor and buy new studs to hold the bearing. I did and it would have been a pain to reuse the old ones.
