refresh my memory
Old Nov 16, 2012 | 11:34 AM
rat49f6's Avatar
rat49f6
refresh my memory
I''m pulling an engine from a friends truck and installing a junkyard engine in place of it
Truck is a e99 replacement engine came from e99 e series bus
I know that the drivers side exhaust manifold is diffrent but will the van one work in the truck?
Ill be using the van turbo with adapter but swap the truck spider onto the engine. Should I use the van pedestal or truck pedestal? Iirc there is a difference
Old Nov 16, 2012 | 11:46 AM
JOHN2001's Avatar
JOHN2001
I dont know if there is a difference between the van or truck pedestal but when I swapped my turbo I just used what was there already... Put the truck pedestal on it just incase
Old Nov 16, 2012 | 01:56 PM
BigAlsPSD's Avatar
BigAlsPSD
Don't know on an E99 Jim, but Late vans, the manifold and oil cooler were different than the truck motor. Had to use truck manifold and oil cooler. I don't have a pic of the manifolds, but if you look at the cooler you can see, it goes the "opposite direction" the F series rise and go up towards the top of the motor, and the E's go towards the bottom.
Old Nov 16, 2012 | 02:25 PM
rat49f6's Avatar
rat49f6
Yeah I think at this point ill just swap it all over
Old Nov 16, 2012 | 02:30 PM
Bonanza35's Avatar
Bonanza35
I wonder if your van cooler would work on a 86 E350 van. I could use one, Mine needs a lot of welding to fix.
Chet
Old Nov 16, 2012 | 02:36 PM
rat49f6's Avatar
rat49f6
Find me a pic of urs on the engine
Old Nov 16, 2012 | 03:44 PM
Bonanza35's Avatar
Bonanza35
If I was good on the computor I'd try, I just don't have much training on pictures and all. Haven't even try to hook a camera up to it.
Shawn MacAnanny
Feb 26, 2016 01:30 PM
lght1
Sep 30, 2013 01:44 PM
mrblonde108
26
Jul 1, 2012 11:39 AM
Kyle_KleinSS
13
Mar 15, 2011 10:00 PM
CriticalMass
Aug 19, 2010 11:29 PM
