Van turbo
Old Aug 19, 2010 | 10:00 PM
CriticalMass's Avatar
CriticalMass
Van turbo
Well, as I mentioned in the other thread I'm swapping an engine from an E450 to an F350. Nothing fancy, just need it to work. I noticed a couple things about the turbo pretty quick....
#1 - the turbo on the E series does not have a wastegate.
#2 - the outlet flange is smaller than the one on my old turbo.
I did notice quite a few threads about people swapping "van turbos" into their trucks, but I couldn't find a detailed outline of what is involved. Can someone tell me what I'm up against here? Is there an adapter to connect to my stock exhaust? Thanks.
Old Aug 19, 2010 | 10:05 PM
rat49f6's Avatar
rat49f6
i would use ur manifolds and up pipes from the original engine as the van engine has different manifolds. then install the van turbo to the sd uppipes.
clay @ riff raff has the adapter you'll need
Riffraff Diesel: Van Turbo Outlet Adapter
Old Aug 19, 2010 | 11:11 PM
7.3 Rocket's Avatar
7.3 Rocket
The van turbo is actually an upgrade from a SuperDuty turbo. You just need the adapter which Jim has already pointed you towards.
Old Aug 19, 2010 | 11:16 PM
CriticalMass
Awesome.... thanks. It even eliminates the EBPV for me. Gonna get one of those and some new up pipes and donuts from Ford.
I had actually already swapped the manifolds over, because there was an interference issue with the F series motor mounts and the oil cooler on the drivers side.... and in order to swap oil coolers (again, interference) I also had to swap manifolds. Which, wasn't too disappointing since they BOTH had broke bolts in the back end.
Old Aug 19, 2010 | 11:21 PM
rat49f6's Avatar
rat49f6
if ur replacing up pipes get these
Riffraff Diesel: IH Bellowed Up-pipe Kit
Old Aug 19, 2010 | 11:29 PM
CriticalMass
They look really nice and I'm sure they would last for all eternity, but I'm pretty much tapped out, for now. Gonna have a bunch of parts for sale though, so I'll have to see what that nets me.
gasgrunt88
May 10, 2010 09:25 AM
bigpowerstroke
Sep 20, 2006 12:10 AM
jtharvey
15
May 27, 2006 01:12 PM
jtharvey
28
May 24, 2006 12:23 AM
edub32
60
Dec 2, 2005 04:03 PM
