Aerostar Ford Aerostar
Weird electrical problem (door locks and dome light)
Old Nov 15, 2012 | 04:45 PM
garbadee's Avatar
garbadee
I have a 1997 Aerostar 4.0L 165k Miles Keyless entry
I am having strange electrical problems. This happens on an unpredictable basis but is getting more frequent (ie. use to be once every couple days and now is happening several times during my 24 mile drive to or from work).
After starting, the car door locks may automatically lock; however, a few seconds later they may lock again, and again, and … This may happen 5-10 times in a row then it stops for 5 minutes or 2 days.
This week a new symptom showed up. The dome light came on while driving. It stayed on for a few seconds then went off. 5 seconds later the doors locked. This may or may not repeat. The light may stay on for 5 or 30 seconds always followed by the doors locking. It may repeat once or sever times in a row. I also noticed if I stepped on the brakes it turned off the dome light and then the doors locked but then it would likely start again. Turning on the headlights did not seem to have any effect.
Any ides?
Ed
Old Nov 15, 2012 | 05:19 PM
Muffinman's Avatar
Muffinman
The keyless entry system key remote most the time is the problem, unless someone went on a wiring job under the dash and pulled something loose. Hard to say without knowing the manufacturer of the system. You might look them up on the internet. See if they have a trouble shooting page.
Old Nov 15, 2012 | 06:18 PM
garbadee's Avatar
garbadee
Was considering the possibility of it being the keyless system but the remote doesn't work if the car is running.
Also it came with the vehicle (ie Ford).
Old Nov 15, 2012 | 06:33 PM
Muffinman's Avatar
Muffinman
Check under the dash and look for the relay. You can change it out and see if that fixes it. also look for any bad connections loose wires. Also there is PC board chip the size of a match book that plugs into a black housing. If pull it out use a pencil eraser to clean the ends. You can tell if its working by taking leaving it out. The car should not start since thats its job. Then put it back in start then remove it. the car should stay running.
Old Nov 15, 2012 | 08:24 PM
garbadee's Avatar
garbadee
Is this all under the dash on the driver's side?
Old Nov 15, 2012 | 08:44 PM
Muffinman's Avatar
Muffinman
Yes just to the left of the steering wheel, stuffed up under the dash. Find that black holder with the starter kill board in it, all that wiring is the system.
Old Nov 16, 2012 | 06:21 PM
garbadee's Avatar
garbadee
Thanks will try to look it over this weekend if I can finish my other honey dews...
Old Nov 16, 2012 | 11:31 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I have the electrical/vacuum book for your van down in the marketplace. Let me know if interested.
Old Nov 17, 2012 | 05:42 AM
Jose A.'s Avatar
Jose A.
here's a link to free electrical diagram downloads for the '97, but it does not have a Keyless Entry system diagram, only Power Locks.
Ford Aerostar System Wiring Diagram Download | Document Buzz
Old Nov 17, 2012 | 08:51 AM
Muffinman's Avatar
Muffinman
The system is not in the manual. You have to call that 800 number on the window driver side. I tried one time and they are worthless and will not help wirh any parts, even the coded key main board they make. They say take it back to the dealer ford service.
Old Nov 17, 2012 | 11:47 AM
Jose A.'s Avatar
Jose A.
is that what they call "Pass The Buck" ??
Old Nov 17, 2012 | 06:32 PM
Muffinman's Avatar
Muffinman
They did it to me sure. I can figured it out anyway.
I does have a good use. You mount that black chip holder down like it should have been with the holder handle and you can take the chip out easier. It kills the whole ignition system till you put it back in.
Old Nov 17, 2012 | 07:40 PM
Jose A.'s Avatar
Jose A.
well I'm glad I don't have that keyless business, I don't trust it. There is nothing like a key.
And now they are making cars with just 1 door lock, no lock on the passenger side door.
I will not buy one like that.
Old Nov 18, 2012 | 09:56 AM
Muffinman's Avatar
Muffinman
If you have the stickers on either door windows at the bottom, its been installed. You just never got the key fobs for it.
dalej
Jul 29, 2017 07:16 PM
GreenMachinee
Electrical Systems/Wiring
Nov 28, 2014 07:06 AM
Icefan71
General Automotive Discussion
Oct 22, 2009 07:58 PM
mworcest
Aug 17, 2007 02:02 PM
Matt M, PA
Jan 26, 2005 12:51 PM
