Sponsored by: Auxito
exhausted.
Old Nov 15, 2012 | 02:17 PM
ronbare's Avatar
ronbare
exhausted.
just bought a 1997 ford f-150 4x4 with 4.6 motor. the check engine light came on. my dianostic tool reads code 401 (egr insufficient flow) i,ve replaced on the parts on the egr side of engine. light still on. could it be a leak in the vacuum lines . i don,t see any wear. need help. ronbare.
Old Nov 15, 2012 | 03:49 PM
Bluegrass 7's Avatar
Bluegrass 7
First mistake is replacing parts on a hope you will get lucky.
The code says insufficient flow.
It's the 'flow' not just parts.
The computer does a test and monitor of EGR gas flow by measueing the difference in pressure accross a .040" hole in a disc in the metal tube (two hoses from the DPFE) one on each side of the disc.
The port behind the EGR may be plugged with carbon stopping flow.
Good luck.
Old Nov 15, 2012 | 07:42 PM
ronbare's Avatar
ronbare
Good luck.
thanks, i,ve got another DPFE. one mechanic told me to only buy the DPFE at the ford dealership.
Old Nov 15, 2012 | 11:01 PM
ronbare's Avatar
ronbare
is it possibe the cpvc valve is not working. i,ll probably replace it.
Old Nov 30, 2012 | 11:22 PM
ronbare's Avatar
ronbare
Smile check engine light.
i cleaned the egr regulator and replace the regulator tubing . i,ve drove over 250 miles and the check engine light has not come on.
treehugger1
1997 - 2003 F150
Sep 4, 2010 09:10 AM
dadsranger
Feb 2, 2010 10:03 AM
Lil Josh
1983 - 2012 Ranger & B-Series
Mar 10, 2008 12:03 AM
yyz87
Modular V8 (4.6L, 5.4L)
Jul 6, 2003 11:27 PM
bunavicz
Jun 5, 2003 01:22 AM
