First turn on the headlights and then rotate the headlight switch **** to see if it can dim or brighten the lights.
Still no dash lights? Check for voltage on each side of the applicable fuse... keep probing downstream or upstream until you find voltage...You do have a voltmeter or test light, right?
My advice remains the same with regard to checking for power on both sides of the fuse. I cannot help you unless you follow my advice and report your results as requested. Replacing fuses is not equivalent.
