new guy
Old Nov 8, 2012 | 09:47 AM
bigrid79's Avatar
bigrid79
new guy
whats up guys , the name is skylar,heres a pic of my rig...
bought an after market tach for the truck and had a few questions......
say run the red wire to a pos source wghen the ignition is on....any one know what color wire in the dash i coudl use for that?.......i have the inline 6 300..it say run the green wire to the coil? is that right?....then i run a ground........also say run the the white to a night lamp...wich wire wopuld that be?....i know its alot of questions but i am brand new to trucks this old of a truck and am getting to know things slowly but steadily!
thanks for yall help!
Old Nov 8, 2012 | 10:53 AM
gpence's Avatar
gpence
Red to a key on powered point, green to the coil, white to a lighted switch & black is a ground
Old Nov 8, 2012 | 11:22 AM
bigrid79's Avatar
bigrid79
so red would be like a wire that turns the cd player on when i start the truck?
Old Nov 8, 2012 | 11:23 AM
bigrid79's Avatar
bigrid79
and as far as the coil do i splice into the wire that is coming from the dizzy?
Old Nov 8, 2012 | 11:32 AM
GOVTMOD's Avatar
GOVTMOD
Welcome to FTE. I like the color.
The radio lead is a easy key on wire to find and the light wire can probably just be spliced in with the light that illuminates the panel above the wiper and headlight switches.
Old Nov 8, 2012 | 11:44 AM
bigrid79's Avatar
bigrid79
this truck has no dash lights..i replaced all the bulbs "taht were blow" and still no lights? som eone told me that the bright light foot switch is a cause of that some times?
Old Nov 8, 2012 | 12:17 PM
fmc400's Avatar
fmc400
MSEE
Answers to questions:
1) GREEN wire on tach goes to coil negative (TACH TEST) terminal. It does not go to the distributor on an electronic ignition setup (factory on your 79).
2) Dimmer switch on the floor has nothing to do with the dash lights; whoever told you otherwise is wrong. Check that you have power on both sides of the dash illumination fuse with the headlight switch pulled out to either stop and the **** turned all the way counter-clockwise.
Old Nov 8, 2012 | 01:29 PM
bigrid79's Avatar
bigrid79
its is turned all the way counter clockwise.....where is the dash ill light located?
Old Nov 8, 2012 | 05:24 PM
fmc400's Avatar
fmc400
MSEE
You're looking for a fuse, not a light. It's in the fuse panel and is labelled. Should be 3 amps. Check it for power using a multimeter or a test light using a known-good ground. Don't just look at it and say that it looks fine. As I said in my previous post, this has to happen with the headlight switch pulled out to one of the two stops (meaning at least the parking lights are on).
catto95
Dec 13, 2015 07:39 PM
norts1138
Aug 25, 2014 06:53 PM
billybodaddo
Oct 25, 2012 10:44 AM
r2000f150
20
Dec 8, 2010 12:24 PM
MonsterBroncoKid
1978 - 1996 Big Bronco
Aug 26, 2004 11:01 AM
