Thoughts on cyclonic CCV separator?
Old Nov 13, 2012 | 04:47 PM
honeydew's Avatar
honeydew
A local friend of mine has been running a BMW cyclonic CCV separator on his 1.9L diesel with good results. The separator is used by BMW on a 5L engine and they use two- one per cylinder bank. Inlet and outlet are 3/4", there is no internal filter media.
My CCV is stock but I've been thinking about a CCV mod when I rebuild the turbo.
Any thoughts on using this on the 7.3L? I'd rather not run multiples in parallel because that is too complex.
Here is a listing for the part: oil separator
BMW part number is: 11151705237
Old Nov 13, 2012 | 11:19 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Makes perfect sense to me. But if they spec two for a 5L motor you may need a jumbo single version to handle 7.3L of displacement. I'd be very curious to know if this works.
Old Nov 14, 2012 | 03:01 AM
Tugly's Avatar
Tugly
3/4" inlet/outlet and a 1/2" oil drain... it would take some plumbing.
Old Nov 14, 2012 | 05:12 AM
SSSimon's Avatar
SSSimon
Are BMW running 2 because they just put a CCV on each head?
The issue is how restrictive it is. The cyclonic effect may be even more cyclonic with more displacement running through it. It's a cheap part. Put it on and hook up some sort of pressure gauge on the inlet or outlet pipe. Any restriction will show up as positive pressure meaning a fail - not too much money wasted to try it.
Would you catch the oil is a sealed container? If not we hit a recursive loop
Old Nov 14, 2012 | 06:33 AM
honeydew's Avatar
honeydew
I'm not sure of their reasoning for 2 on the 5L, will ask my friend if he knows.
I would run the drain to a catch can, BMW returns it to the sump.
Thanks for the replies everybody.
Jesser02EX
24
Oct 13, 2013 08:35 PM
bkuuz1
Sep 10, 2013 08:42 AM
68GTFastback
Mar 3, 2008 09:01 PM
RobertJohn
13
Feb 25, 2008 11:30 PM
Hiflyer746
13
Feb 23, 2007 10:24 AM
